What are viable options and alternatives you can think of to accomplish this kind of wireless communication for telemetry and remote control?
Goal:
Interface Raspberry Pi controller with sensors/remotes, with main constraints being on ATmega side in terms of sketch size and RAM usage. RPi will send commands to, and receive notifications and telemetry from, these ATmegas.
Brief background:
I aim to build sensors based on ATmega (currently Arduino pro mini) and nRF24L01+. Some will also have remote controllable devices connected, such as lights.
My communication will be toward Raspberry Pi, running Python (preferably), interfacing nRF24L01+ over hardware driven SPI.
I'm using AES-256 for CBC-encryption and SipHash-2-4 as MAC to protect the data over the air from eavesdropping, MITM and replay attacks. (May sound like overkill but it's been fairly straight forward and simple.)
nRF24L01+ can send at most 32 bytes per transmission, so my initial 32-byte package will contain an 8-bytes start sequence including number of encrypted blocks, a 16-byte initialization vector for AES, and an 8-byte MAC for the first 24 bytes.
After this, encrypted blocks will arrive in 2x16 bytes, ending with a MAC. Or possibly interleaved with MACs so I can start to decrypt without waiting for the whole sequence, and thus reduce the need to buffer data. I will only decrypt that which has a valid MAC.
Constraints:
My largest sketch so far, with most debugging code disabled, takes up roughly 19 / 30 kB program storage and 1.5 / 2 kB RAM. It is mostly done, and already using as many of the intended function calls to external libraries as possible for a complete picture, although I have not yet implemented everything in detail.
Preferably the incoming data should be possible to process as a stream, up to 16 or 32 bytes at a time. If I can avoid parsing everything at once, I require less buffer space. (RAM is precious on the ATmega.)
Current alternatives:
Google Protocol Buffers using nanopb - adds roughly 7 kB program storage for encode/decode of simple sensor data.
Benchmarks indicate the stack usage is potentially too high for me, although they do claim to use a very large message with all different types represented.
The overhead is high, but this is otherwise a very tempting and flexible option. -
Adafruit_Sensor framework, or something similar, with simple (and rigid) data structure.
Will require a little bit more effort to design and implement for both ATmega and Python on Raspberry Pi.
(See initial question at the top. :))
