[Q] Using USB & SDcard Simultaneously (Mount Point)
TL;DR: How do I force the sdcard to always be mounted on /dev/sda?
When I boot my arduino with an sdcard installed but without a usb drive, the webpage stored in sd is accessible. Additionally, I can upload sketches with webpages and it will update the file on the sdcard.
If I plug in a USB drive, it continues to work normally. However, if I remove power and allow it to boot completely while the USB drive is connected, it will mount the USB at /dev/sda, which is where it looks for the webpage. The Arduino appears to always mount USB first if it is booting up.
How can I change this? I need the webpage to be stored on the sd and still allow the arduino to boot from with a USB drive connected for secondary file storage.
Any ideas
If you create a folder called arduino in your sdcard you will find it as /dev/sd.
The sda or sdb device will be always created and it will depends on the order you plug the devices. But if there is the arduino folder inside the sdcard it will appear always as /dev/sd and it does not depends on the plug order.
Angelo9999:
Sorry, I made a mistake. You will find it under mnt so it is /mnt/sd.
It is a symbolic link to the respective device under /dev.
