So I'm not sure if it's a problem with X-Sim or the Arduino code, chances are it's the code that is causing issues.
Anyways, so about three years back, herctrap made a USB instrument cluster for use with LFS, and I couldn't find any other "tutorials" or codes in that were whole enough to make something like that myself.
I got my hands onto X-Sim and the cluster, broke out the arduino and got going, I've altered the code to fit my cluster, and a few mods here and there.
However, it seems like it's either reading, only the first letter being sent from X-Sim, since I can't get both the speedo and the rev counter working at the same time, if I put "R~a01~" first in the Axis definition box in X-Sim, Arduino reads that and makes the RPM Counter work, switch that with "S~a02~" and it makes the speedo work.
Put both in, "R~a01~S~a02~" in that order, only RPM counter works, if I switch it, making it say "S~a02~R~a01~" only the speedo works.
I know, it's confusing but I did my best to explain it ;_;
Help please? I'll post the code either here or on pastebin including some screencaps from the X-Sim software if that's needed.
