qmc5883L in matlab.
HEllo..
I want to see magnetcompass data in matlab but now on, I don't know how to do,
What I confussed is i2c program.
You know that qmc5883L is I2c device.
And it's OKay to use in arduino sketch using this library.
However, when I write a code in matlab,readRegister, I don't know how to do.
It's find to do dev and uint16 but, I don't know how to use register.
So I was check 1 to 255 value and that is this.
64015 4093 64980 54526 65028 1460 46070 63005 7424 1 257 256 65280 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 15 3843 768 65280 65280 65476 50944 199 50432 0 0 65280 65280 65280 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 160 65440 65461 65468 65454 65459 65459 65451 65459 65459 65454 65429 65435 65454 65464 65451 65459 65464 65456 65451 65451 65443 65459 65456 65443 65451 65461 65459 65454 65464 65459 65464 65445 65445 65461 65470 65451 65454 65448 65456 65454 65435 65456 65464 65456 65451 65468 65459 65478 65461 65445 65456 65451 65438 65445 65464 65464 65448 65451 65456 65451 65451 65435 65448 65459 65473 65451 65448 65451 65443 65448 65451 65456 65464 65445 65459 65464 65468 65443 65445 65451 65489 65461 65426 65443 65459 65454 65438 65451 65459 65454 65454 65459 65464 65440 65454 65459 65461 65448 65454 65454 65484 65464 65459 65459 65480 65451 65454 65464 65468 65451 65459 65473 65461 65459 65443 65448 65470 65435 65443 65459 65461 65435 65451 65451 65461 65468 65464 65461 65459 65468 65443 65475 65470 65448 65443 65454 65459 65461 65459 65473 65461 65478 65454 65448 65456 65461 65438 65454 65451 65459 65451 65448 65461 65470 65451 65454 65443 65475 65454 65454 65456 65454 65468 65440 65461 65454 65454 65448 65445 65461 65470 65459 65445 65459 65456 65454 65459 65456 65468 65456 65445 65456 65464 65468 65468 65456 65456 65454 65440 65445 65459 65445
I'm sorry about this large Matrix...
I don't know how to use this to show x y z and azimuth value.
Please help me :frowning:
QMC5883L Datasheet 1.0 .pdf (1.04 MB)
We can't help with Matlab questions.
Most us don't have it.
have you read thru
Matlab support for arduino
and managed to get a simple program such as blinking a LED operational?
post your matlab code?
if you are going to control the QMC5883L directly from Matlab you will have to send the commands to configure the device and read information.
it may be simpler to use the QMC5883L arduino library and then transmit the data to Matlab using Serial.print() etc as in the example code
then use the Matlab serial interface to read the information
