qre1113 sensor
I have a qre1113 sensor to detect black and white colors, but when trying to measure distances instead of colors, I leave the code.
// code
int s1,s2,s3,s4,s5,s6,s7,s8;
int sb1,sb2,sb3,sb4,sb5,sb6,sb7,sb8;
s1 = analogRead(A1);
s2 = analogRead(A2);
s3 = analogRead(A3);
s4 = analogRead(A4);
s5 = analogRead(A5);
s6 = analogRead(A6);
s7 = analogRead(A7);
s8 = analogRead(A8);
sb1 = map(s1, 0, 1023, 0, 255);
sb2 = map(s2, 0, 1023, 0, 255);
sb3 = map(s3, 0, 1023, 0, 255);
sb4 = map(s4, 0, 1023, 0, 255);
sb5 = map(s5, 0, 1023, 0, 255);
sb6 = map(s6, 0, 1023, 0, 255);
sb7 = map(s7, 0, 1023, 0, 255);
sb8 = map(s8, 0, 1023, 0, 255);
Serial.print(" A1=" );
Serial.print(sb1);
Serial.print(" A2=" );
Serial.print(sb2);
Serial.print(" A3=" );
Serial.print(sb3);
Serial.print(" A4=" );
Serial.print(sb4);
Serial.print(" A5=" );
Serial.print(sb5);
Serial.print(" A6=" );
Serial.print(sb6);
Serial.print(" A7=" );
Serial.print(sb7);
Serial.print(" A8=" );
Serial.print(sb8);
Serial.println("...");
Yes, and? You would benefit by learning about arrays. We would all benifit if you were to read the "how to use the forum" stickies.
(deleted)
The QRE1113 is a very short range device - of the order of a few millimetres.
Because you have all those analogRead() statements but have not told us what they are for I wonder if your description of what you want to do is misleading.
And this sort of thing won't work properly
because the 2nd reading will be getting remnants of the 1st one and the 3rd will be getting remnants of the 2nd etc.
Do it like this
so that you read each pin twice and discard the first reading.
And, as mentioned elsewhere, learn about arrays.
...R
