Hello,
I am currently working on a prototype that has two QT1103 chips on it. Each chip has 10 capacitive touch sensors. I am using the QTouch1Wire library of Dave Vondle.
The library is working perfect for one chip, but I am unable to readout both chips at the same time or one by one.
Is this something someone already figured out or does someone has an idea? For now I am using the simple polling example:
Qtouch QT1103 1-wire serial example
polls and prints the status of the capacitive pads.
if you have the E1103 evaluation board, the pads are layed out in the 2x5 grid like:
96574
81203
Created 23 November 2009
By Dave Vondle
#include <Qtouch1wire.h>
#define ONEWIREPIN 3
unsigned int value;
OneWire.begin(ONEWIREPIN, 9600); // should be > 8000 according to datasheet
Serial.begin(19200);
delay(100);
value = OneWire.requestRead();
if(value>>8 & B00000001){
Serial.print("0");
else{
Serial.print(" ");
if(value>>8 & B00000010){
Serial.print("1");
else{
Serial.print(" ");
if(value>>8 & B00000100){
Serial.print("2");
else{
Serial.print(" ");
if(value>>8 & B00001000){
Serial.print("3");
else{
Serial.print(" ");
if(value>>8 & B00010000){
Serial.print("4");
else{
Serial.print(" ");
if(value>>8 & B00100000){
Serial.print("5");
else{
Serial.print(" ");
if(value & B00000001){
Serial.print("6");
else{
Serial.print(" ");
if(value & B00000010){
Serial.print("7");
else{
Serial.print(" ");
if(value & B00000100){
Serial.print("8");
else{
Serial.print(" ");
if(value & B00001000){
Serial.print("9");
else{
Serial.print(" ");
if(value & B00010000){
Serial.print("10");
else{
Serial.print(" ");
Serial.print(" ");
Serial.println(value, BIN);
Thanx!
