I am using a qtr8-rc sensor array on a line following robot, When I use it on a black line on a white surface it works but when i try to use it on a black surface with white line i can’t get correct results, i have extracted the following code from my robot to test it separately but no matter what i do i can not get it to detect white line on a black surface…
#include "PololuQTRSensors.h"
PololuQTRSensorsRC qtr;
void setup(){
qtr.init((unsigned char[]) {2,3,4,5,6,7,9}, 7);
int i;
for (i = 0; i < 250; i++){ // make the calibration take about 5 seconds
qtr.calibrate(QTR_EMITTERS_ON);
delay(20);
void loop(){
unsigned int val[7];
qtr.readCalibrated(val);
int line = qtr.readLine(val,QTR_EMITTERS_ON,true);
Serial.print(line);
Serial.print(" R< ");
Serial.print(val[0]); Serial.print(" ");
Serial.print(val[1]); Serial.print(" ");
Serial.print(val[2]); Serial.print(" ");
Serial.print(val[3]); Serial.print(" ");
Serial.print(val[4]); Serial.print(" ");
Serial.print(val[5]); Serial.print(" ");
Serial.print(val[6]); Serial.print(" ");
Serial.print(val[7]); Serial.print(" ");
Serial.println(" >L ");
Some sample reading I am getting,
3200 R< 553 473 397 113 120 533 304 104 >L
3432 R< 567 514 474 113 120 393 82 104 >L
3494 R< 572 625 544 94 100 487 69 104 >L
3418 R< 543 421 506 88 93 305 64 104 >L
3407 R< 529 403 487 69 73 290 50 104 >L
3403 R< 524 397 480 62 67 284 46 104 >L
3506 R< 538 561 474 37 40 264 27 104 >L
3503 R< 538 543 455 18 20 248 13 104 >L
3519 R< 558 567 474 44 46 269 32 104 >L
3537 R< 577 590 500 69 73 290 50 104 >L
3545 R< 577 614 532 94 100 310 69 104 >L
3466 R< 611 497 397 94 100 310 69 104 >L
3534 R< 572 584 500 62 67 284 46 104 >L
All numbers are way too close so readLine does not return a correct position. One of the pins on my arduino does not work so I skipped connecting one of the sensors(sensor 7)
