Quad 12-bit DAC MCP4728 problem
Hi, I've been trying to get a "GY MCP4728" break out board to work.
https://www.aliexpress.com/i/32975204887.html
I've not been able to find any info on the particular board but with a little guesswork...
I'm connecting it to a 5v ATMega 328P Arduino Mini Pro.
I've connected CL to SCL, DA to SDA, R to GND and I've left L hanging.
I've installed this library:
and tried to compile the example sketch.
First problem. At "Wire.begin(21, 22);" I get the following error:
Arduino: 1.8.7 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
/var/folders/cd/qk843k6s1zg29k1shf789pfh0000gn/T/arduino_modified_sketch_754247/example.ino: In function 'void setup()':
example:10:22: error: no matching function for call to 'TwoWire::begin(int, int)'
Wire.begin(21, 22);
In file included from /var/folders/cd/qk843k6s1zg29k1shf789pfh0000gn/T/arduino_modified_sketch_754247/example.ino:1:0:
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.h:52:10: note: candidate: void TwoWire::begin()
void begin();
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.h:52:10: note: candidate expects 0 arguments, 2 provided
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.h:53:10: note: candidate: void TwoWire::begin(uint8_t)
void begin(uint8_t);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.h:53:10: note: candidate expects 1 argument, 2 provided
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.h:54:10: note: candidate: void TwoWire::begin(int)
void begin(int);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.h:54:10: note: candidate expects 1 argument, 2 provided
exit status 1
option enabled in File -> Preferences.
So to be honest i don't understand any of that but i took a look at the sketch in the examples folder on the github page and noticed that line of code was different. It reads "Wire.begin();" instead of "Wire.begin(21, 22));".
That version of the code compiles, loads and runs on my arduino but it appears to lock up at " dac.attatch(Wire, 14);".
It does run if a unplug the dac but that's no use :slight_smile:
Can anyone spot any errors or make any suggestions to help me get this module running? Thanks.
@clockworkrobot, you have posted a new question in a very old Thread so I have suggested to the Moderator to move you to your own Thread
...R
I presumed this was the place as the library documentation references this thread but no need to move it as, not entirely sure why but I tried the code here:
and again it wouldn't run, until i disconnected it from the computer then i noticed it was working fine.
I guess it was something to do with the serial out not playing nice with the i2c.
Thanks.
@clockworkrobot
TOPIC SPLIT
DO NOT HIJACK !
Could you take a few moments to READ THIS.
It will help you get the best out of the forum.
Bob.
@clockworkrobot, I suggest you now edit your Original Post (in this Thread) and change the Title so it reflects the correct hardware for your question.
...R
