quad copter stability problem
when i try to tuning my quad copter it becomes crazy
i tied two axles and free the other 1 axis is on and the other off
i don’t use rf remote i control it with my pc
any help
here is the code
////////***********Sensor Configuration****************////
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
#define OUTPUT_READABLE_YAWPITCHROLL
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
////**************************END Sensor Configuration*************************/////
///***************************My Configuration***************************///////////
int Angle[2]={0,0};
int v_x=130 ;
float Kp=0.001 ;
unsigned long dt=0;
int Error=0, Des_angle=0,lastError=0;
float I=0,Kd=0,Ki=0;
float D=0;
unsigned long Now ,lastTime;
int a , b;
char button;
int dd=0;
long instI=0;
//////with glue  Pin 9
/////the other pin 10
  /**************************Sensor Setup*********************************///
        Wire.begin();
        TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
    Serial.println(F("Initializing QuadCopter Devices..."));
    mpu.initialize();
    Serial.println(F("Testing devices connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    mpu.setXGyroOffset(220);
    mpu.setYGyroOffset(76);
    mpu.setZGyroOffset(-85);
    mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
    if (devStatus == 0) {
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        packetSize = mpu.dmpGetFIFOPacketSize();
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
  ///////**************************End Sensor Setup****************************/////////
  ///*********************************************My Setup*****************************//////////
  ///initiate motors pins
  DDRB|=1<<1;
  DDRB|=1<<2;
     //initiate Timer2
// Timer/Counter 2 initialization
// Clock source: System Clock
// Clock value: 250.000 kHz
// Mode: Phase correct PWM top=0xFF
// OC2A output: Inverted PWM
// OC2B output: Inverted PWM
TCCR1A=0xF1;
TCCR1B=0x03;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=v_x;
OCR1BH=0x00;
OCR1BL=v_x;
  Now = millis();
  if (dt<20)
 dt=45;
  Angle[0]= ( ypr[1] * 180/M_PI) -6;
  Angle[1]= ypr[2] * 180/M_PI;
  a=OCR1AL;
  b=OCR1BL;
 ///*************************************Sensor Loop**********************////////
  if (!dmpReady) return;
    while (!mpuInterrupt && fifoCount < packetSize) {
    fifoCount = mpu.getFIFOCount();
    if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
        mpu.resetFIFO();
        } else if (mpuIntStatus & 0x02) {
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        fifoCount -= packetSize;
        #ifdef OUTPUT_READABLE_YAWPITCHROLL
            mpu.dmpGetQuaternion(&q, fifoBuffer);
            mpu.dmpGetGravity(&gravity, &q);
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
            Serial.print("XY-Angle\t\t\t");
            Serial.print(Angle[1]);
            Serial.print("\t\t");
            Serial.print(Error);
            Serial.print(a);
            Serial.print(b);
            Serial.print(v_x);
            Serial.print(Kp*10);
            Serial.print(Kd*10);
            Serial.println(Ki*1000);
        #endif
   ///************************************* End Sensor Loop**********************////////
    //*********************************************My Loop**************************************//
  if ( millis() >=10000 )
  ///PID Logarithm
  Error= Des_angle - Angle[1] ;   // stable desired angle = 0
  D=(Error-lastError);
  D/=dt;
  lastError=Error;
  instI=Error * dt;
  I=I+instI  ;
 if ( Error == 0 )
      I=0;
  if (abs(I)<180)
    I=0;
 else if ((I>20250)&&(I>0))
    I=20250;
    else if ((I<-20250)&&(I<0))
    I=-20250;
    if (v_x<=118)
     OCR1AL= v_x - (Kp * Error) -(D * Kd) - (I*Ki);
     OCR1BL= v_x + (Kp * Error) +( D * Kd) + (I*Ki) ;
     OCR1AL= v_x ;
     OCR1BL= v_x  ;
    OCR1AL= v_x - (prop_x * Error) - (D*Pd) - (I*Pint) ;
     OCR1BL= v_x + (prop_x * Error) +( D*Pd) + (I*Pint) ;
    ///Pc interface
  if(Serial.available())
      button = Serial.read ();
      Serial.println(button);
      //increase speed
      if (button == 'w')
       if (v_x==130)
        v_x=123 ;
       v_x-=1;
      //decrease speed
      if (button == 's')
       if (v_x==130)
        v_x=130 ;
      else if (v_x==123)
       v_x=123;
       v_x+=1 ;
       ///increase   prop_x
       if(button=='p')
       Kp+=0.001;
      //decrease prop_x
      if(button=='m')
       Kp-=0.001;
       if(button=='e')
       v_x=130;
      if(button=='o')
       Kd+=0.001;
      //decrease prop_x
      if(button=='n')
       Kd-=0.001;
      if(button=='i')
       Ki+=0.00001;
      //decrease prop_x
      if(button=='b')
       Ki-=0.00001;
  button = 0 ;
lastTime = millis ();
dt= lastTime-Now ;
hello I'm Antonino Lagati end I'm working on a MPU6050 sarkfun and use a code similar to yours but does not compile error .................... MPU6050 mpu; how did you manage to make it run? thanks
By downloading and installing the proper library, obviously.
Have you tried the angle calculation using this http://hobbylogs.me.pn/?p=47 library.
