Quadcopter help
Hi there!
Me and a friend of mine are building our own quadcopter, but we need some help because we’re stuck on the controls.
The parts:
4X NTM prop drive series 1200kv 286W
4x Hobbyking 30A blueseries ESC
1x Turnigy 3300mAh 3S 30C Lipo
1x Arduino Duemilanove (wATmega168)
Here is a quick drawing on how everything is connected:
We use four motors and ESC’s to control our quad. As seen above one ESC and motor are drawn, the others are exactly the same (except for the pin numbers which are 9, 10, 11 and 12).
Both of us are totally new to coding, and we have 0 experience.
The ESC’s respond with a signal width from 700 to 2000. With 700 being a programming mode, and 1000-2000 the flying mode. The motors start spinning at 1047 with minimum speed and go full throttle on 2000.
We can now control all four motors with the same speed, but obviously we need to be able to control each motor individually. Note: we have no gyrostabilisor, so we are not planning on flying outside since this is just a project for school.
We need to be able to set throttle for each motor, but have no idea how.
This is the code we found (and modified) to control four motors (each on their own signal channel 9, 10, 11 and 12).
#include <Servo.h>
int value = 0; // set start value
Servo firstESC, secondESC, thirdESC, fourthESC; //includes four ESC's
  firstESC.attach(9);
  secondESC.attach(10);
  thirdESC.attach(11);
  fourthESC.attach(12);
  firstESC.writeMicroseconds(value); //select first ESC
  secondESC.writeMicroseconds(value); //select second ESC
  thirdESC.writeMicroseconds(value); //select third ESC
  fourthESC.writeMicroseconds(value); //select fourth ESC
  if(Serial.available())
    {value = Serial.parseInt();
     Serial.println(value);}
This code is very simple and we have no idea how to expand it so we can set throttle for each motor.
Our idea was to control the quad from a smartphone with an app via bluetooth, and because the motor throttle goes in steps (1000-2000) we thought it’d be handy to make a sort of step setup, so we can set throttle by +50+100, but for each motor.
So that if we click ‘forward’ the back motors spin +50 faster than the front motors, and if we click ‘up’ all four motors go +50 at once) (NOTE: we have an X-setup quadcopter not a +)
Is someone able to help us out?
TLDR:
We need help with this code so we can set throttle for each motor (pin 9/10/11/12) individually, and throttle/direction goes with steps (throttle ranges from 1000 to 2000) and our idea was throttle would go with +50/-50 etc etc.
Thanks in advance, our project depends on your help because we are stuck!
Individual motors.ino (622 Bytes)
Programmeerprogramma.ino (632 Bytes)
Single motor.ino (707 Bytes)
Then I hope you are making your quadcopter out of indestructium.
Don't worry about the material, IF we actually get it airborne we will make sure it's safely attached to wires so it cannot crash, or hit the ceiling.
We just need help with the code, please someone help us because we're stuck.
Is there really no one who can help us out?
You have chosen a project that is really difficult, even for experienced programmers.
Given this:
You're so out of your depth that I suspect the folks that read this thread just shook their heads and moved on.
I suggest you start with something much easier, to build up the skills you'll need to succeed with your ultimate goal.
I would look up some examples of quadcopter codes and calibration first before anything else. Second make sure you only attach one red wire from the form the controller to the arduino, they feed power back and so they can fry your board... Trust me on that one... Thirdly attack the code one peice at a time start with how will you get the controll inputs, then on math of how they combine to get you the out put
