Hi all!
I want to control a quadcopter running a lowlevel control algorithm on a ground based PC. Therefore, I need to uplink the four rotor commands at high frequency (>10^2 Hz) and low latency (<10^1 ms).
The idea is to use a 3DR radio https://store.3drobotics.com/products/3dr-radio to send serial commands.
I wrote my own very simple protocol: Each command consists of 2 byte payload (that includes 2 bit rotor ID and 1 parity bit) + 1 byte delimiter (’~’ → 126).
The rotors receive the commands correctly, but the latency seems to be far to high… =(
As I am not an experienced ARDUINO user, the code might not be efficient!?
// Controlling four ecs' using a serial input
// include libs
#include <Servo.h>
// declare and initialize variables
byte serialdata[3] = {0}; // 2 bytes of data + 1 endbyte
int rotorID = 0; // rotor ID
int sum = 0; // sum over bits
unsigned serialint[4] = {0}; // rotor signals
Servo rotor1, rotor2, rotor3, rotor4;
// initialize serial port
Serial.begin(115200); // set baud rate
// initialize servos
rotor1.attach(A0);
rotor1.write(0);
rotor2.attach(A1);
rotor2.write(0);
rotor3.attach(A2);
rotor3.write(0);
rotor4.attach(A3);
rotor4.write(0);
// clear variables
sum = 0;
rotorID = 0;
if (Serial.available() >= 3){
// read 3 bytes from serial buffer
for (int i=0; i<3; i++){
serialdata[i] = Serial.read();
// check for correct byte order
if (serialdata[2] == 126){
// sum bits
for (int j=0; j<8; j++){
sum = sum + bitRead(serialdata[0],j) + bitRead(serialdata[1],j);
// validity check
if (sum%2 == 0){
// set rotor ID
if (bitRead(serialdata[1],5) == 0 && bitRead(serialdata[1],6) == 0){
rotorID = 1;
else if (bitRead(serialdata[1],5) == 1 && bitRead(serialdata[1],6) == 0){
rotorID = 2;
else if (bitRead(serialdata[1],5) == 0 && bitRead(serialdata[1],6) == 1){
rotorID = 3;
else if (bitRead(serialdata[1],5) == 1 && bitRead(serialdata[1],6) == 1){
rotorID = 4;
else{
// no valid rotor ID found
// calculate updated servo position
for (int k=0; k<3; k++){
bitClear(serialdata[1],5+k);
serialint[rotorID-1] = serialdata[0]+serialdata[1]*256; // assemble bytes
serialint[rotorID-1] = map(serialint[rotorID-1], 0, 800, 30, 130); // map to valid range
else{
// data not valid
else {
// no data available
// set servo positions
rotor1.write(serialint[0]);
rotor2.write(serialint[1]);
rotor3.write(serialint[2]);
rotor4.write(serialint[3]);
Any help is grately appreciated.
Thanks,
Stefan
