I'm doing a Quadcopter with brushed motors and Arduino, connecting the engine to a 3.7 volt battery (600 mAh ), the image is of a WLtoys V999 and does not weigh much , the problem is that my motors of 4 of them placed in analogWrite (motor, 255) and the quadricopter does not rise , because what does not rise ? :o
Because the props are mounted the wrong way round?
So what half-H-bridges are you using for each motor?
Whats the weight of the Quadcopter?
Sounds like you dont have much power available given the battery size.
Can you post a picture of your project please.
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.htm
Tom...
