I’m attempting to program my own quadcopter flight control board using an Arduino Uno. I’m using DJI 30A ESCs and a Turnigy 9x8c v2 Receiver.
When I connect the throttle output (CH3) directly to one of the ESCs, the motor spins happily. But when I read the throttle PWM value and then output it to the ESC via the Uno ( using analogWrite(PIN,VALUE) ), nothing happens. I can’t seem to get the ESCs to move the motors at all using a PWM signal from the Uno.
When connected, I get the power up chime indicating that the ESC is seeing a PWM signal. If I turn off the PWM signal, I get error beeps from the ESC. My PWM output signal is mirroring that of the Rx and ranges between 1060 and 1888 us.
I can’t figure out what is different between the Uno output and the Receivers. Do any of you quadcopter designers out there have any experience with this? What am I missing?
Note: The DJI ESCs do not require a calibration procedure.
