quadrature encoder not counting anti clock wise
guys,
i have been working on the following encoder from element 14
1.http://sg.element14.com/bourns/pec11r-4225f-s0024/encoder-incremental-2ch-60rpm/dp/2381866?ost=2381866&selectedCategoryId=&categoryNameResp=All&searchView=table&iscrfnonsku=false
i am sing basic counting code ,the encoder doesnt count anti clockwise,
i have pasted the code below kindly help me
/* Read Quadrature Encoder
  • Connect Encoder to Pins encoder0PinA, encoder0PinB, and +5V.
  • Sketch by max wolf / www.meso.net
  • v. 0.1 - very basic functions - mw 20061220
int val;
int encoder0PinA = 3;
int encoder0PinB = 4;
int encoder0Pos = 0;
int encoder0PinALast = LOW;
int n = LOW;
pinMode (encoder0PinA,INPUT);
pinMode (encoder0PinB,INPUT);
Serial.begin (9600);
n = digitalRead(encoder0PinA);
//Serial.println
if ((encoder0PinALast == LOW) && (n == HIGH))
if (digitalRead(encoder0PinB) == HIGH )
// Serial.println("entered");
encoder0Pos--;
encoder0Pos++;
Serial.println (encoder0Pos);
// Serial.println ("/");
encoder0PinALast = n;
Can you confirm with a very simple digitalRead() sketch that you can see HIGH and LOW transitions on encoder0PinB which is digital pin 4.
no, the encoder0pinb gives a constant high output,
Do you have pulldown resistors on the encoder pins?
http://www.farnell.com/datasheets/1785154.pdf
You need pull up resistors.
The encoder is in the broken line box below.
Tom… :slight_smile:
All you need is to change:
to
   pinMode (encoder0PinA,INPUT_PULLUP);
   pinMode (encoder0PinB,INPUT_PULLUP);
Read both pins unconditionally at the top of the loop.
byte pinAState;
byte pinBState;
  byte pinAPrevState = pinAState;
  byte pinBPrevState = pinBState;
  pinAState = digitalRead(pinA);
  pinBState = digitalRead(pinB);
Quadrature logic is:
If A has gone high, then forward if B is high, else backward.
If A has gone low, then backward if B is high, else forward.
If B has gone high, then backward if B is high, else forward.
If B has gone low, then forward if B is high, else backward.
more compactly:
if(pinAPrevState != pinAState) if(pinA == pinB) count++; else count--;
if(pinBPrevState != pinBState) if(pinA == pinB) count--; else count++;
Couple this with what Paul said:
