Quadrature encoder output values continuously climbing (Teensy 4.0)
The encoder has A+ A- B+ B- VCC and GND pins. When I connect A+ and B+ to the teensy on various pins and run the following code my serial output is just a continuously, and rapidly, climbing set of numbers. Any tips?
#include <Arduino.h>
#include <Encoder.h>
// Change these two numbers to the pins connected to your encoder.
//   Best Performance: both pins have interrupt capability
//   Good Performance: only the first pin has interrupt capability
//   Low Performance:  neither pin has interrupt capability
Encoder myEnc(3, 4);
//   avoid using pins with LEDs attached
  Serial.println("Basic Encoder Test:");
long oldPosition  = -999;
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
I guess the A- and B- pins must be connected too. Post a link to the datasheet of the device!
The encoder needs to have Vcc and GND connected, as well.
