quadrature encoder reading
Hi everybody
I have an Dagu rover 5 with 2 encoders, a Dagu channel 4 and a arduino mega 1280.
I want to read via the encoders how far it has driven and in wich direction, and make it drive a certain distance.
When i run the code it only display this as encoder output 0 -1 0 1 0 -1 0 1 0 1(when te wheels are turning),
If i turn of the wheels by disconnecting the power i get a normal encoder ouput 0 1 2 3 4 5 6 7 8 9 10
This is my Code:
#include <Encoder.h>
#define PwmPinMotorA 8
#define PwmPinMotorB 11
#define DirectionPinMotorA 9
#define DirectionPinMotorB 10
Encoder myEnc(2, 3); // encoder pins connected to pin D2 and D3
int message = 0;     //  This will hold one byte of the serial message
  Serial.println("Basic Encoder Test:");
  pinMode(PwmPinMotorA, OUTPUT);
  pinMode(PwmPinMotorB, OUTPUT);
  pinMode(DirectionPinMotorA, OUTPUT);
  pinMode(DirectionPinMotorB, OUTPUT);
void forward(){
digitalWrite(DirectionPinMotorA, HIGH);
analogWrite(PwmPinMotorA, 25);
digitalWrite(DirectionPinMotorB, LOW);
analogWrite(PwmPinMotorB, 25);
void hold(){
digitalWrite(DirectionPinMotorA, LOW);
analogWrite(PwmPinMotorA, 0);
analogWrite(PwmPinMotorB, 0);
long oldPosition  = -999;
  long newPosition = myEnc.read();
      if (Serial.available() > 0) { //  Check if there is a new message
      message = Serial.read();    //  Put the serial input into the message
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
if (newPosition < 50){
  forward();
else{
hold();
Are the encoders picking up interference from the motors perhaps?
Try to separate the wires of the encoder from the wires carrying power to the motor as far as you can. Another way is to twist the power and ground to the motor wires into twist pairs to reduce interference. You then run a separate ground wire to the encoder.
