Queries regarding RF transmitter receiver module
Hi guys, I'm making an RF bot and I want to know if I could send alphabets like 'w', 'a' etc. via the transmitter or only binary digits (0, 1). Also, I'm looking forward to solder a wire as an antenna. Is it helpful to hook up a wire as an antenna? Thanks for all the help :slight_smile: . Here's my code
//Transmitter Code (Nano)
#include <VirtualWire.h>
  vw_setup(2000);
  vw_set_tx_pin(7);
  if(Serial.available())
    char c = Serial.read();
    if(c == 'w')
      vw_send((uint8_t *)c, 1);
    else if(c == 's')
    else if(c == 'a'){
    else if(c == 'd')
    else if (c == 'x'){
//Reciever Code (Uno)
#include <AFMotor.h>
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
motor1.setSpeed(175);
motor2.setSpeed(175);
  vw_setup(2000);
  vw_set_rx_pin(7);
  vw_rx_start();
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  uint8_t buf[buflen];
  if(vw_get_message(buf, &buflen))
    for(int i = 0;i < buflen;i++)
      if(buf[i] == 'w')
        motor1.run(FORWARD);
        motor2.run(FORWARD);
      else if(buf[i] == 'a')
        motor1.run(BACKWARD);
      else if (buf[i] == 's') {
        motor2.run(BACKWARD);
      else if(buf[i] == 'd'){
    else if(buf[i] == 'x'){
      motor1.run(RELEASE);
      motor2.run(RELEASE);
What RF units are you using?
An antenna wire will make quite a difference.
Tom.... :slight_smile:
Thanks , here is my module(attachment)
As far as the circuit goes, I am planning right now so I'll provide it in a day or two.
Also, can I use letters or do I have to use binary digits.
ecgeek:
For those, you may find this to be of use. Author (he's a forum member too) provides a protocol for sending actual messages and has a sketch for each end, Rx and Tx.
Image from Reply #2 so we don't have to download it. See Image Guide
...R
