Query in Extended Data Base
Hello everybody,
I want to create a data base in Arduino for data logging of informations inputed by a PS/2 keyboard.
Each record will include several data (a "serial number" of the record, a "name", a "time" in hours and minutes, and other three text variables).
I need to know how/if is possible to query the data base, in order to find a "name": if the new entry has the same name of a previously entered one, the new record will not be stored in the data base.
Any existing application? Thanks for your help.
Yes.
How are you storing the data? How much data are you storing? What kind of interesting data are you getting from a keyboard?
Thank you for the reply.
I'm just beginning the sketch.
I'm working on a log for amateur radio contest (if it is useful to know): during the competition the log is filled (in a SD card or a USB pen, what is the easiest way). Then the log is downloaded into a PC for its arrangement and mailing to the contest committee.
Each record has the following data: 1) transmitted serial number (001, 002, 003, ... up to 999) - automatically incremented by software after the input of the previous record has been completed; 2) received callsign (10 alphanumeric digits, A..Z, 0..9 and slash /); 3) received report (3 decimal units, e.g. 599); 4) received serial number (3 decimal units, like pos. 1); 5) received geographical locator WWL (6 alphanumeric digits - 2 letters, 2 decimal units, 2 letters); 6) time at end of record input (hours and minutes).
Except for pos. 1 and 6, all the data are inputed by keyboard.
Even if 999 records are out of imagination, 200-300 records are a realistic in a good contest scoring.
Meanwhile, a second data base is filled with the inputed callsign and related geographical locator(s), so that they can be suggested during a new contest.
Thank you in advance.
A record consists of 3 + 10 + 3 + 3 + 6 + 4 (or more) characters, for a total of 29 or more. The SRAM on a typical Arduino is 2048 bytes. That's enough space for 69 records IF there is no overhead. There is plenty of overhead involved with the Extended Data Base process.
Even a Mega would be able to store only 276 records, with no overhead.
