My digital Multimeter work correctly it is measure DC (voltage current resistance capacitance) but I want to add AC voltage to this project
I will attach the total code for you
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "logo.h"
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 32
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
const int select_button = 2;
const int right_button = 3;
const int OhmMeter = A0;
const int CapacitancMeter = A1;
const int VoltMeter = A2;
const int Ammeter = A3;
const int R3 = 6;
const int R2 = 5;
const int R1 = 4;
const int ChargePin = 13;
const int DischargePin = 11;
boolean is_select = false;
int navigator = 0;
int flag = 0;
float R = 0.00;
float V = 0.00;
float I = 0.00;
float C = 0.00;
float t = 0.00;
float P = V*I;
float E = P*t;
boolean nano = false;
boolean kilo = false;
boolean mili = false;
void OLED_init() {
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C))
Serial.println(F("SSD1306 allocation failed"));
for (;;);
display.clearDisplay();
diplay_logo(15, 3, Electropeak, F_LOGO_WIDTH, F_LOGO_HEIGHT);
display.display();
delay(2000);
display_clear();
void display_clear() {
display.display();
void diplay_logo(int x, int y, const uint8_t *bitmap, int w, int h) {
display.drawBitmap(x, y, bitmap, w, h, WHITE);
void display_text(int sz, int x, int y, String str) {
display.setTextSize(sz);
display.setTextColor(WHITE);
display.setCursor(x, y);
display.println(str);
void display_number(int sz, int x, int y, double num) {
display.println(num);
void calculate_resistor() {
float v_ref = 4.94;
float r1 = 0.00;
float r_ref1 = 1000.00;
float adc_value1 = 0.00;
float voltage1 = 0.00;
float r2 = 0.00;
float r_ref2 = 10000.00;
float adc_value2 = 0.00;
float voltage2 = 0.00;
float r3 = 0.00;
float r_ref3 = 100000.00;
float adc_value3 = 0.00;
float voltage3 = 0.00;
pinMode(R1, OUTPUT);
pinMode(R2, INPUT);
pinMode(R3, INPUT);
digitalWrite(R1, HIGH);
for (int i = 0; i < 20 ; i++)
adc_value1 = adc_value1 + analogRead(OhmMeter);
delay(3);
adc_value1 = adc_value1 / 20;
if (adc_value1 < 1022.90)
voltage1 = ((adc_value1 * v_ref) / 1024);
r1 = (voltage1 * r_ref1) / (v_ref - voltage1);
pinMode(R1, INPUT);
pinMode(R2, OUTPUT);
pinMode(R3, INPUT);
digitalWrite(R2, HIGH);
adc_value2 = adc_value2 + analogRead(OhmMeter);
delay(3);
adc_value2 = adc_value2 / 20;
if (adc_value2 < 1022.90)
voltage2 = ((adc_value2 * v_ref) / 1024);
r2 = (voltage2 * r_ref2) / (v_ref - voltage2);
pinMode(R1, INPUT);
pinMode(R2, INPUT);
pinMode(R3, OUTPUT);
digitalWrite(R3, HIGH);
adc_value3 = adc_value3 + analogRead(OhmMeter);
delay(3);
adc_value3 = adc_value3 / 20;
if (adc_value3 < 1022.90)
voltage3 = ((adc_value3 * v_ref) / 1024);
r3 = (voltage3 * r_ref3) / (v_ref - voltage2);
r1 = r1 / 1000;
r2 = r2 / 1000;
r3 = r3 / 1000;
if (r1 < 2 && r2 < 101 && r3 < 1001) R = r1 * 1000;
else if (r1 > 2 && r2 < 101 && r3 < 1001) R = r2;
else if (r1 > 2 && r2 > 101 && r3 < 2000) R = r3;
else R = 0.00;
if (R < 1)
R = R * 1000;
kilo = false;
kilo = true;
void calculate_capacitance() {
unsigned long start_time;
unsigned long elapsed_time;
float microFarads;
float nanoFarads;
float r_ref = 10000.00;
digitalWrite(ChargePin, HIGH);
start_time = millis();
while (analogRead(CapacitancMeter) < 648) {}
elapsed_time = millis() - start_time;
microFarads = ((float)elapsed_time / r_ref) * 1000;
if (microFarads > 1)
C = microFarads;
nano = false;
nanoFarads = microFarads * 1000.0;
C = nanoFarads;
nano = true;
digitalWrite(ChargePin, LOW);
pinMode(DischargePin, OUTPUT);
digitalWrite(DischargePin, LOW);
while (analogRead(CapacitancMeter) > 0) {}
pinMode(DischargePin, INPUT);
void calculate_voltage() {
float R1 = 9950.00;
float R2 = 4670.00;
float v_ref = 5.00;
float resistor_ratio = 0.00;
float adc_value = 0.00;
float voltage = 0.00;
resistor_ratio = (R2 / (R1 + R2));
for (int i = 0; i < 200 ; i++)
adc_value = adc_value + analogRead(VoltMeter);
delay(3);
adc_value = adc_value / 200;
voltage = (adc_value * v_ref) / 1024;
V = voltage / resistor_ratio;
void calculate_current() {
int sensitivity = 185;
int adc_value = 0;
float v_ref = 4.94;
float pure_voltage = 0.00;
float offset_voltage = 2.47;
for (int i = 0; i < 40 ; i++)
adc_value = adc_value + analogRead(Ammeter);
delay(2);
adc_value = adc_value / 40;
voltage = ((adc_value * v_ref) / 1024);
pure_voltage = voltage - offset_voltage;
pure_voltage = pure_voltage * 1000;
I = pure_voltage / sensitivity;
if (I < 1)
I = I * 1000;
mili = true;
mili = false;
OLED_init();
pinMode(right_button, INPUT_PULLUP);
pinMode(select_button, INPUT_PULLUP);
pinMode(ChargePin, OUTPUT);
if (digitalRead(right_button) == 0)
navigator++;
while (digitalRead(right_button) == 0);
delay(5);
if (navigator > 3) navigator = 0;
Serial.println(navigator);
if ( digitalRead(select_button) == 0)
is_select = true;
while ( digitalRead(select_button) == 0);
if (navigator == 0)
diplay_logo(0, 0, RightArrow, F_LOGO_WIDTH, F_LOGO_HEIGHT);
display_text(2, 17, 8, "Resistor");
display.display();
while (is_select)
display_text(1, 0, 0, "Resistor");
display_text(2, 12, 8, "R=");
display_number(2, 42, 8, R);
if (kilo) display_text(1, 115, 15, "k");
display.display();
calculate_resistor();
is_select = false;
if (navigator == 1)
diplay_logo(0, 0, BothArrow, F_LOGO_WIDTH, F_LOGO_HEIGHT);
display_text(2, 17, 8, "Voltage");
display.display();
while (is_select)
display_text(1, 0, 0, "Voltage");
display_text(2, 12, 8, "V=");
display_number(2, 42, 8, V);
display_text(1, 115, 15, "v");
display.display();
calculate_voltage();
is_select = false;
if (navigator == 2)
display_text(2, 17, 8, "Current");
display.display();
while (is_select)
display_text(1, 0, 0, "Current");
display_text(2, 12, 8, "I=");
display_number(2, 42, 8, I);
if (mili) display_text(1, 115, 15, "mA");
if (!mili) display_text(1, 115, 15, "A");
display.display();
calculate_current();
is_select = false;
if (navigator == 3)
diplay_logo(0, 0, LeftArrow, F_LOGO_WIDTH, F_LOGO_HEIGHT);
display_text(2, 12, 8, "Capacitor");
display.display();
while (is_select)
display_text(1, 0, 0, "Capacitor");
display_text(2, 12, 8, "C=");
display_number(2, 42, 8, C);
if (nano) display_text(1, 115, 22, "nF");
if (!nano) display_text(1, 115, 22, "uF");
display.display();
calculate_capacitance();
is_select = false;
