Question about AdaFruit ILI9341 library
The snippet below is from AdaFruit_ILI9341.cpp
It's the first lines of the initcmd array used to send setup info to the display.
Anyone know what the first seven lines do? I don"t see these commands in
the ILI9341 datasheet.
static const uint8_t PROGMEM initcmd[] = {
  0xEF, 3, 0x03, 0x80, 0x02,
  0xCF, 3, 0x00, 0xC1, 0x30,
  0xED, 4, 0x64, 0x03, 0x12, 0x81,
  0xE8, 3, 0x85, 0x00, 0x78,
  0xCB, 5, 0x39, 0x2C, 0x00, 0x34, 0x02,
  0xF7, 1, 0x20,
  0xEA, 2, 0x00, 0x00,
  ILI9341_PWCTR1  , 1, 0x23,             // Power control VRH[5:0]
No, I don't know what 0xEF does. But this is the sequence from an Ilitek app note. The value in square brackets are the factory default value.
        static const uint8_t ILI9341_regValues_2_4[] PROGMEM = {        // BOE 2.4"
            0xF6, 3, 0x01, 0x01, 0x00,  //Interface Control needs EXTC=1 MV_EOR=0, TM=0, RIM=0
            0xCF, 3, 0x00, 0x81, 0x30,  //Power Control B [00 81 30]
            0xED, 4, 0x64, 0x03, 0x12, 0x81,    //Power On Seq [55 01 23 01]
            0xE8, 3, 0x85, 0x10, 0x78,  //Driver Timing A [04 11 7A]
            0xCB, 5, 0x39, 0x2C, 0x00, 0x34, 0x02,      //Power Control A [39 2C 00 34 02]
            0xF7, 1, 0x20,      //Pump Ratio [10]
            0xEA, 2, 0x00, 0x00,        //Driver Timing B [66 00]
David.
The datasheet at AdaFruit is an earlier version; version 1.11 documents these commands.
