Question about ADC and bluetooth
It's a radar sensor project, what I want to do is make arduino pro receive analog data from A3, converts to digital data, then transmit to laptop through bluetooth. I have ADC code like this:
int analogPin = 3;
int val = 0;
val = analogRead(analogPin);
Serial.println(val,DEC);
And I have a bluetooth example code like this:
#include <SoftwareSerial.h>
int bluetoothTx = 2; // TX-O pin of bluetooth mate, Arduino D2
int bluetoothRx = 3; // RX-I pin of bluetooth mate, Arduino D3
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
bluetooth.begin(9600);
if(bluetooth.available())
Serial.print((char)bluetooth.read());
if(Serial.available())
bluetooth.print((char)Serial.read());
The problem is I don't know how to combine them together =( =(
Can anyone one teach me how to program the board so that it can receive data from A3, and transmit through D3 with bluetooth?
The bluetooth code seems to be a test for 2 way traffic and you probably don't need it
Does the ADC code work? i.e., do you see the result on the serial monitor? If so, the code is fine. Can you configure your bluetooth to work on pins 0,1 standard serial? If so, and I'm sure it is possible, the ADC code is all you need, you use the same code for the bluetooth.
Here is some background you might find helpful.
ttp://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
