Question About "Application of the Kalman Filter to Rocket Apogee Detection" by David W. Shultz
Hello,
First, I found the study I will be mentioning in this question here: A Kalman filter for Altitude via Pressure, Temp and Acceleration - Using Arduino / Sensors - Arduino Forum
I want to write an arduino code to implement kalman filter. My case is almost same with the one in the KalmanApogeeII file. I want to detect apogee with a barometric pressure sensor (BMP280) and an accelerometer (Adafruit BNO055). But there is something I couldn't understand in the code. This is the code in the file.
NAME
 rkal32.c - A third order Kalman filter for
RDAS interpreted data files.
SYNOPSIS
 rkal32 [model] <infile >outfile
model is an optional parameter to specify the ratio
between the variance for the acceleration measurement
(fixed) and the model (variable). Default value for
this is that the model is about 100 times better
than the measurement.
DESCRIPTION:
 Performs Kalman filtering on standard input
 data using a third order, or constant acceleration,
 propagation model.
 The standard input data is of the form:
 Column 1: Time of the measurement (seconds)
 Column 2: Acceleration Measurement (feet/sec/sec)
 Column 3: Pressure Measurement (altitude in feet)
 The standard output data is of the form:
 Column 1: Time of the estimate/measurement
 Column 2: Pressure Measurement
 Column 3: Acceleration Measurement
 Column 4: Position estimate
 Column 5: Rate estimate
Column 6: Acceleration estimate
AUTHOR
 Hacked by David Schultz
REPORTING BUGS AND REVISIONS
mailto:david.schultz@earthlink.net
COMPILING
 cc -o rkal32.exe rkal32.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#define ALTITUDESIGMA 15.0
#define ACCELERATIONSIGMA 6.0
#define MODELSIGMA 0.6
double altitude_variance = ALTITUDESIGMA*ALTITUDESIGMA;
double acceleration_variance = ACCELERATIONSIGMA*ACCELERATIONSIGMA;
double model_variance = MODELSIGMA*MODELSIGMA;
main(int argc, char ** argv)
char buf[512];
int i, j, k, notdone;
double alt_inovation, accel_inovation;
double time, accel, pressure;
double last_time, last_pressure;
double det;
double est[3] = { 0, 0, 0 };
double estp[3] = {0, 0, 0 };
double pest[3][3] = { 2, 0, 0,
 0, 9, 0,
 0, 0, 9 };
double pestp[3][3] = { 0, 0, 0,
 0, 0, 0,
 0, 0, 0 };
double phi[3][3] = { 1, 0, 0,
 0, 1, 0,
 0, 0, 1.0 };
double phit[3][3] = { 1, 0, 0,
 0, 1, 0,
 0, 0, 1.0 };
double kgain[3][2] = { 0.01, 0.01,
0.01, 0.01,
 0.01, 0.01 };
double lastkgain[3][2], dt;
double term[3][3];
/* check for model variance parameter */
if (argc == 2)
double temp;
temp = atof(argv[1]);
model_variance = acceleration_variance/temp;
/* Initialize */
/* Skip text at start of file. */
while(1)
if(gets(buf) == NULL)
fprintf(stderr, "No data in file\n");
exit(1);
if( strstr(buf, "-2.000"))
sscanf(buf, "%lf %lf %lf", &time, &accel, &pressure);
est[0] = pressure;
last_time = time;
fprintf(stderr, "No data\n");
exit(1);
 dt = time - last_time;
last_time = time;
Fill in state transition matrix and its transpose
 phi[0][1] = dt;
 phi[1][2] = dt;
 phi[0][2] = dt*dt/2.0;
 phit[1][0] = dt;
 phit[2][1] = dt;
 phit[2][0] = dt*dt/2.0;
 /* Compute the Kalman gain matrix. */
 for( i = 0; i <= 2; i++)
for( j = 0; j <=1; j++)
 lastkgain[i][j] = kgain[i][j];
 k = 0;
 while(1)
 /* Propagate state covariance */
 term[0][0] = phi[0][0] * pest[0][0] + phi[0][1] * pest[1][0] + phi[0][2] * pest[2][0];
 term[0][1] = phi[0][0] * pest[0][1] + phi[0][1] * pest[1][1] + phi[0][2] * pest[2][1];
 term[0][2] = phi[0][0] * pest[0][2] + phi[0][1] * pest[1][2] + phi[0][2] * pest[2][2];
 term[1][0] = phi[1][0] * pest[0][0] + phi[1][1] * pest[1][0] + phi[1][2] * pest[2][0];
 term[1][1] = phi[1][0] * pest[0][1] + phi[1][1] * pest[1][1] + phi[1][2] * pest[2][1];
 term[1][2] = phi[1][0] * pest[0][2] + phi[1][1] * pest[1][2] + phi[1][2] * pest[2][2];
 term[2][0] = phi[2][0] * pest[0][0] + phi[2][1] * pest[1][0] + phi[2][2] * pest[2][0];
 term[2][1] = phi[2][0] * pest[0][1] + phi[2][1] * pest[1][1] + phi[2][2] * pest[2][1];
 term[2][2] = phi[2][0] * pest[0][2] + phi[2][1] * pest[1][2] + phi[2][2] * pest[2][2];
 pestp[0][0] = term[0][0] * phit[0][0] + term[0][1] * phit[1][0] + term[0][2] * phit[2][0];
 pestp[0][1] = term[0][0] * phit[0][1] + term[0][1] * phit[1][1] + term[0][2] * phit[2][1];
 pestp[0][2] = term[0][0] * phit[0][2] + term[0][1] * phit[1][2] + term[0][2] * phit[2][2];
 pestp[1][0] = term[1][0] * phit[0][0] + term[1][1] * phit[1][0] + term[1][2] * phit[2][0];
 pestp[1][1] = term[1][0] * phit[0][1] + term[1][1] * phit[1][1] + term[1][2] * phit[2][1];
 pestp[1][2] = term[1][0] * phit[0][2] + term[1][1] * phit[1][2] + term[1][2] * phit[2][2];
 pestp[2][0] = term[2][0] * phit[0][0] + term[2][1] * phit[1][0] + term[2][2] * phit[2][0];
 pestp[2][1] = term[2][0] * phit[0][1] + term[2][1] * phit[1][1] + term[2][2] * phit[2][1];
 pestp[2][2] = term[2][0] * phit[0][2] + term[2][1] * phit[1][2] + term[2][2] * phit[2][2];
 pestp[2][2] = pestp[2][2] + model_variance;
 Calculate Kalman Gain
 det = (pestp[0][0]+altitude_variance)*(pestp[2][2] + acceleration_variance) - pestp[2][0] * pestp[0][2];
 kgain[0][0] = (pestp[0][0] * (pestp[2][2] + acceleration_variance) - pestp[0][2] * pestp[2][0])/det;
 kgain[0][1] = (pestp[0][0] * (-pestp[0][2]) + pestp[0][2] * (pestp[0][0] + altitude_variance))/det;
 kgain[1][0] = (pestp[1][0] * (pestp[2][2] + acceleration_variance) - pestp[1][2] * pestp[2][0])/det;
 kgain[1][1] = (pestp[1][0] * (-pestp[0][2]) + pestp[1][2] * (pestp[0][0] + altitude_variance))/det;
 kgain[2][0] = (pestp[2][0] * (pestp[2][2] + acceleration_variance) - pestp[2][2] * pestp[2][0])/det;
 kgain[2][1] = (pestp[2][0] * (-pestp[0][2]) + pestp[2][2] * (pestp[0][0] + altitude_variance))/det;
 pest[0][0] = pestp[0][0] * (1.0 - kgain[0][0]) - kgain[0][1]*pestp[2][0];
 pest[0][1] = pestp[0][1] * (1.0 - kgain[0][0]) - kgain[0][1]*pestp[2][1];
 pest[0][2] = pestp[0][2] * (1.0 - kgain[0][0]) - kgain[0][1]*pestp[2][2];
 pest[1][0] = pestp[0][0] * (-kgain[1][0]) + pestp[1][0] - kgain[1][1]*pestp[2][0];
 pest[1][1] = pestp[0][1] * (-kgain[1][0]) + pestp[1][1] - kgain[1][1]*pestp[2][1];
 pest[1][2] = pestp[0][2] * (-kgain[1][0]) + pestp[1][2] - kgain[1][1]*pestp[2][2];
 pest[2][0] = (1.0 - kgain[2][1]) * pestp[2][0] - kgain[2][0] * pestp[2][0];
 pest[2][1] = (1.0 - kgain[2][1]) * pestp[2][1] - kgain[2][0] * pestp[2][1];
 pest[2][2] = (1.0 - kgain[2][1]) * pestp[2][2] - kgain[2][0] * pestp[2][2];
/* Check for convergance. Criteria is less than .001% change from last
 * time through the mill.
notdone = 0;
 k++;
 for( j = 0; j <= 1; j++)
 if( (kgain[i][j] - lastkgain[i][j])/lastkgain[i][j] > 0.00001)
notdone++;
if( notdone )
 continue;
 printf("Input noise values used (standard deviation):\n");
 printf("#Altitude - %15f feet\n", sqrt(altitude_variance));
 printf("#Acceleration - %15f feet/sec/sec\n", sqrt(acceleration_variance));
 printf("#Model noise - %15f feet/sec/sec\n#\n", sqrt(model_variance));
 printf("#Kalman gains converged after %d iterations.\n#", k);
 printf("%15f ", kgain[i][j]);
 printf("\n#\n");
 printf("#Estimated output first order statistics (standard deviation):\n");
 printf("#Altitude - %15f feet\n", sqrt(pest[0][0]));
 printf("#Velocity - %15f feet/sec\n", sqrt(pest[1][1]));
 printf("#Acceleration - %15f feet/sec/sec\n", sqrt(pest[2][2]));
 /* Now run the Kalman filter on the data using previously
 * determined gains.
Output header for data.
printf("#\n# Output from rkal32:\n# A third order Kalman filter using acceleration and pressure measurements\n");
printf("# Time Press. Alt. Acceleration Est Pos Est Rate Est Accel\n#\n");
 while( gets(buf) != NULL)
 /* remove offset and convert from G's to ft/sec/sec */
 accel = (accel-1.0)*32.17417;
 /* sanity check on time */
 if( last_time >= time )
 fprintf(stderr, "Time does not increase.\n");
 exit(1);
 /* Compute the innovations */
 alt_inovation = pressure - estp[0];
 accel_inovation = accel - estp[2];
/* Experimental code to modify Mach transition pressure
 * disturbances.
 if( abs(alt_inovation) > 100 )
 /* We have a large error in altitude. Now see how fast we are
 * going.
 if( estp[1] > 900 && estp[1] < 1200 )
 /* Somewhere in the neighborhood of Mach 1. Now check to
 * see if we are slowing down.
 // if( estp[2] < 0 )
 * OK, now what do we do? Assume that velocity and
 * acceleration estimates are accurate. Adjust current
 * altitude estimate to be the same as the measured
 * altitude.
 est[0] = pressure;
 alt_inovation = 0;
 /* Simple check for over-range on pressure measurement.
 * This is just hacked in based on a single data set. Actual
 * flight software needs something more sophisticated.
 if( pressure > 37000)
 alt_inovation = 0;
 /* Propagate state */
 estp[0] = phi[0][0] * est[0] + phi[0][1] * est[1] + phi[0][2] * est[2];
 estp[1] = phi[1][0] * est[0] + phi[1][1] * est[1] + phi[1][2] * est[2];
 estp[2] = phi[2][0] * est[0] + phi[2][1] * est[1] + phi[2][2] * est[2];
Update state
 est[0] = estp[0] + kgain[0][0] * alt_inovation + kgain[0][1] * accel_inovation;
 est[1] = estp[1] + kgain[1][0] * alt_inovation + kgain[1][1] * accel_inovation;
 est[2] = estp[2] + kgain[2][0] * alt_inovation + kgain[2][1] * accel_inovation;
Output
printf("%15f %15f %15f %15f %15f %15f\n", time, pressure, accel, est[0], est[1], est[2]);
last_time = time;
Starting from line 80 [if (argc == 2)]. Why it was checked if there was only two arguments?
What is the second argument?
And at line 84, why acceleration variance was divided by this data in order to find model variance?
If this last question is about a mathematical subject please let me know. Although I know what a variance is and how it is calculated I am not too familiar.
Thanks in advance
Depending on the number of arguments, appropriate actions have to be taken. The arguments are described in the writeup.
SYNOPSIS
rkal32 [model] outfile
If you have questions about code, post the code, using code tags.
I see thanks. I edited the post.
So it was checked if that optional model parameter is given. And if it was given it should have a value of 1/100 of the acceleration.
Hello,
I have some questions again. Since topic title doesn't specify the question I thought it would be better to ask here again.
Only one acceleration is read: Is this resultant of acceleration vectors or vertical acceleration?
 * determined gains.
Do I need to pass only kalman gain matrix? What about X or P?
  1. Do you have any suggestions, other studies or resources that will help me understand kalman filter and this code? I am really having a hard time comprehending.
Thanks
  1. vertical acceleration
  2. that is a comment describing the program flow
  3. Dan Simon's book "Optimal State Estimation" is excellent. Download his short description of the Kalman Filter here: (PDF) Kalman filtering | Dan Simon - Academia.edu
