Hi guys,
I'm currently working on a vacuum cleaner project, which can be triggered wireless through GSM shield module.
Main components that I'm using are:
- Arduino UNO
- Two DC geared motors. (draws 0.1A each)
- One micro Servo. (draws approx. 0.2A)
- One turbine fan. (draws 0.1A)
- One GSM shield. (draws 2A for transmitting burst)
For the power supply, I'm using a 5V 2A power bank.
So, is the supply sufficient? Because I've heard that the USB cable can only draw 0.5A at max.
Current Progress
When I was just testing for the robot part (without GSM module), everything is working & fine.
However, when I assembled it with the GSM module, the servo is not responding after a signal is received, but the DC motors are moving.
Hence, I don't think that there's any problem with my wireless triggering code.
Is it caused by the insufficient power supply ? As I was planning to use a more powerful supply such as LiPo battery.
Thanks guys ~ appreciate for your help.
