question about "bool" varriables
Hello world,
i would like to make a mash heater wich is guided by an arduino (uno).
my qeustion is about the bool varriable:
in the following code, i wanted to increase the temperature, till it reaches a certain pont. From there on i would like to keep the temperature above said pont.
void TempRegelung(){
  if(Tempanstieg = true){
    if(TempZustand > 480){            //480= arbitrayry point picked from my thermoresistor
      digitalWrite(LedPin,HIGH);      //my thermorestor sits at ~500 at room temp
    }else {                           //the value of it decreases if it gets warmer
      digitalWrite(LedPin,LOW);
      Tempanstieg = false;
      delay(500);                     //added to see if the loop moves on or got stuck here
  if(Tempanstieg = false){
    if(Temphalten = true){
      if(TempZustand > 470){
      }else{
There fore i thought i make a system with two bool variable. When the set temperature is reached, the first bool turns to = false and so the loop should move on to the next if() function where the next bool var. is included. But the function does not move on.
the complete code:
const byte LedPin = 4;
const byte TempPin = A5;
int TempZustand;              //a varable for the temperatur
bool Temphalten = true;
bool Tempanstieg = true;
  pinMode(LedPin,OUTPUT);
  pinMode(TempPin,INPUT);
  TempRead();
  TempRegelung();
      }else{
void TempRead(){                            //a function to see the temp. on the serial monitor
  TempZustand = analogRead(TempPin);
  Serial.print("TempFühler: ");
  Serial.println(TempZustand);
edit: i simply forgott in the if functions the second "=".
sorry to bother
= is assignment, == is comparison. See the reference for the if structure.
Beware of accidentally using the single equal sign (e.g. if (x = 10) ). The single equal sign is the assignment operator, and sets x to 10 (puts the value 10 into the variable x). Instead use the double equal sign (e.g. if (x == 10) ), which is the comparison operator, and tests whether x is equal to 10 or not. The latter statement is only true if x equals 10, but the former statement will always be true.
Comparison is == not =.
