Question about char array
Hello, if i have a char array for example
char Str0[6] = "hello";
char Str1[16] = "hellototheworld";
and in the middle of the program i do something like sprintf(Str1,"%s.txt", Str0); Str1 will be hello.txt\0 which is 9 bytes plus NULL character. What happens to the bytes that was after this position in the first declaration of Str1?
They are still there. Try
Serial.println(&Str1[10]);
It will print the remainder of the string "world".
Pete
Nothing, they are still in memory exactly where you left them. It is just that with a null in the middle any string print stops at that point. This is why strings are a bad idea on an embedded processor with limited memory.
So, a char array Str1 will always need 16 bytes even if i do something like memset(&Str1, 0, sizeof(Str1)); and this "cleaning" it's unnecessary?
Once you declare it to be 16 bytes long, that's it. All that memset does is set each of the 16 characters to a null byte, it doesn't get rid of Str1.
Pete
So which is the best way to use undefined lenght strings?
EDIT: Functions like sprintf, and others that are used to make strings in char arrays, add the NULL character automatically i just need to declare a char array with enough space?
Exactly. If the maximum length of the string is N characters you must declare its length to be at least N+1.
Pete
And the last one... what does the & before char array means? Like &Str1
the '&' in its usage there returns the address of the variable: however your version is wrong ( for memset ):
&Str1;
The correct usage for the memset function is similar to this:
&Str1[10];
Str1 is an array, so without indirection '[]' its a pointer to the start of the array, so you can just write:
memset(Str1, 0, sizeof(Str1));
which is equivalent to:
memset( &Str1[0], 0, sizeof(Str1));
Also moving the starting pointer is simple:
char *Str3 = &Str1[10]; //This simply gets the 11'th char in str1, then returns the address of it.
//which is the same as:
char *Str3 = ( Str1 + 10 );
This is all different to using the '&' symbol to denote references or bitwise AND. i.e
//Reference var
int &i_Ref = somevar;
//Parameters by reference
void Func( int &i_RefParam );
//Bit wise
if( a & B ){}
