can help pleas , thise my code for generator auto start stop it work fine .
int IGN = 6; //Ignition Pin
int SW = 7; //Starter Pin
int GEN = 5; //generator RPM pin
int LINE= 8;
uint32_t Start_Time = 3000; //10 seconds to allow starter to run per attempt
uint32_t Wait_Time = 3000; //30 seconds to wait between start attempts to allow starter to cool
const unsigned long sampleTime = 1000;
int long Gen_Shutdown_Time = 0;
int Current_Time = 0;
int Time_Left = 0;
int IGN_Attempt = 0;
int Genstate = 0;
int Linestate = 0;
//this is to indicate if generator manual started or automated.
Serial.begin(9600); //enable serial connection for debug. Switch any oled.print to serial.print to send to serial
pinMode(GEN,INPUT);
pinMode(LINE,INPUT);
digitalWrite(GEN,HIGH);
digitalWrite(LINE,HIGH);
pinMode(IGN,OUTPUT);
pinMode(SW,OUTPUT);
void linestate() {
int Linestate= digitalRead(LINE); //current pin state
if(digitalRead(LINE)==LOW) {
Linestate=HIGH;
Serial.println("GRID ON");
else {
if(digitalRead(LINE)==HIGH) {
Linestate=LOW;
Serial.print("GRID OFF");
void genstate() { //generator loop to look at current generator state
int Genstate=digitalRead(GEN);
if(digitalRead(GEN)==LOW) { //Check the RPMs of the generator and 500 or higher is running
Serial.println("operation");
Genstate=HIGH;
else {
if(digitalRead(GEN)==HIGH) { //Check the RPMs of the generator and 500 or higher is running
Genstate =LOW; //Set GenState to low indicating generator is not running
void genstart() { //Generator start sequence
if(IGN_Attempt<3&&digitalRead(GEN)==HIGH) { //Try this for 3 attempts with Generator at low and less than as starts with attempt 0
IGN_Attempt++; //add one count to start attempts
Serial.print(IGN_Attempt);
Serial.println(" of 3 attempts");
Serial.println("Gen not running");
Serial.println("Ignition on");
digitalWrite(IGN,HIGH); //Ignition On
delay(2000); //wait 2 second before starter attempt
Serial.println("Starter on");
for( uint32_t timer = millis(); (millis()-timer) < Start_Time; ) { //start a timer in milliseconds called timer and compare to time set against Start_Time
digitalWrite(SW,HIGH); //Starter On
genstate();
if(digitalRead(GEN)==LOW) { //generator running
Serial.println("Starter off");
digitalWrite(SW,LOW); //Starter off
Serial.println("Generator running");
delay(1);
digitalWrite(SW,LOW); //Starter Off
genstate();
//if Start loop complete and genrator not running wait 30 sec before next attempt but if 3rd attempt no reason to delay since wont try start attempt again
if(digitalRead(GEN)==HIGH &&IGN_Attempt < 3) {
Serial.println("Tried for 10 seconds");
Serial.println("Failed to start");
Serial.println("Wait 30 seconds");
for( uint32_t timer2 = millis(); (millis()-timer2) < Wait_Time; ) {
else {
if(digitalRead(GEN)==LOW) { //change to RPM to indicate generator running
IGN_Attempt=0;
else { //Generator did not start so shutdown everything
genshutdown();
Serial.println("Failed to start!");
Serial.println("Please check");
Serial.println("generator!");
void genshutdown() { //Generator shutdown sequence
Serial.print("Generator");
Serial.println("shutdown");
digitalWrite(IGN,LOW);
delay(1);
linestate(); //get ac pole voltage info
genstate(); //get generator run status
int Genstate= digitalRead(GEN);
int Linestate = digitalRead(LINE);
if(digitalRead(LINE) == HIGH ) { //This indicates the AC voltage sensor on pole side of power has been lost or brown out and 10 helps with initial start
Serial.println("Power lost");
genstart();
else { //if AC power from the pole is available
if( digitalRead(LINE) ==LOW) { //if generator is running
Serial.println("Generator OFF");
genshutdown();
delay(1);
delay(800);
IGN_Attempt=0; //reset ignition attempts
i want compine this code with this code (ethernet web server switch on off)
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
Ethernet shield attached to pins 10, 11, 12, 13
Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
String RECIEVER;
String RECIEVER2;
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
byte gateway[] = { 172, 17, 91, 1 };
IPAddress ip(172, 17, 91, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
pinMode(8,INPUT);
digitalWrite(8,HIGH);
pinMode(9,OUTPUT);
while (!Serial) {
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
int S =(digitalRead(8));
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
RECIEVER += c;
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (RECIEVER.length() < 50) {
RECIEVER2 += c;
if (RECIEVER2.indexOf("pin9=off") > 0 ) {
digitalWrite(9, HIGH);
else if (RECIEVER2.indexOf("pin9=on") > 0 ) {
digitalWrite(9, LOW);
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("</br>");
client.println (" <center>");
client.println("<font size='60%' color='black'> ");
client.println("<table border='4' <td align='center '> GENERATOR POWER CONTROL </td> </table>");
client.println(" </center>");
client.println("</font>");
client.println("<CENTER>");
client.println(" <h2> SWICH1 <a href=\"/?pin9=on\"\"> <button > ON </button> </a> ");
client.println(" <a href=\"/?pin8=OFF\"\"> <button > OFF </button> </a> ");
client.println("</CENTER>");
client.println(" <h2>GRID ");
if (S==LOW)
client.print(" ON ");
client.print("OFF ");
client.println("</h2>");
//client.println(RECIEVER2);
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
delay(1);
RECIEVER = " ";
RECIEVER2 = " ";
// close the connection:
client.stop();
Serial.println("client disconnected");
how i can do this please
