I have successfully made two DC motors run using an h-bridge and a 9v power supply.
However, now I am trying to get two DC motors to run that only need 5v. Do I still need to use an h-bridge or can I just run the motor straight from the arduino.
That is EXTEREMELY likely to damage the processor. At a minimum, you will need a transistor between the pin and motor. Hopefully, you can get some ideas here…
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
http://www.thebox.myzen.co.uk/Workshop/Motors_2.html
And a kickback diode to protect the transistor…
Dunc.
If you want to drive the motors with the ability to control speed/direction you need an hbridge (same circuit, just your supply would be 5v instead of 9v). If you just want to switch the motor on/off you can use a transistor and diode.
For the record, an hbridge is just a packaged circuit of a bunch of transistors, so if you want, you can make your own (it won’t be as small, of course).
