Question about Driver DIP Switches
Hello,
Could someone explain how changing the DIP switches on a driver (for stepping not amperage) effects the movement of the motor.
For example: If I switch my driver from [{S1-OFF S2-OFF S3-ON} (MS 16, P/R 3200)] to [{S1-OFF S2-OFF S3-OFF} (MS 32, P/R 6400)] is it a flat increase in distance travelled? So instead of 2" of travel per se it would travel 4"?
Thank you,
D
You need to provide a link to the datasheet for your stepper driver.
...R
Stepper Motor Basics
Simple Stepper Code
Robin2:
...R
Simple Stepper Code
https://www.amazon.com/MYSWEETY-TB6600-Stepper-Driver-Controller/dp/B01MYMK1G9/ref=sr_1_4?ie=UTF8&qid=1529356974&sr=8-4&keywords=microstep+driver the only data I can find is the info on the amazon page I bought it from
The various settings seem to be printed on the cover. Take a photo of that and of the DIP switches and post them here. See this Simple Image Guide
...R
changing from 1/16 microstepping to 1/32 microstepping reduces the effect of a step by a factor of two
(hardly surprizing if you think about it - the steps are smaller)
