Hi to all,
I don't figure out how to manage error codes.
My situation is this:
I'm working with Arduino IDE using ESP32.
When I send out data using ESP-NOW system,
I check the return from send function, to check if the message is sent or not.
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &OutMessage, sizeof(OutMessage));
if (result == ESP_OK) {
Serial.println("Sent with success");
else {
Serial.println(result);
But if I try to get the error code like this:
I have only numeric error codes.
Is there a way to have the text? (e.g. ESP_OK)
Hi sevenoutpinball,
the error code list of esp_err_t is the following:
ESP_OK : succeed
ESP_ERR_ESPNOW_NOT_INIT : ESPNOW is not initialized
ESP_ERR_ESPNOW_ARG : invalid argument
ESP_ERR_ESPNOW_INTERNAL : internal error
ESP_ERR_ESPNOW_NO_MEM : out of memory
ESP_ERR_ESPNOW_NOT_FOUND : peer is not found
ESP_ERR_ESPNOW_IF : current WiFi interface doesn’t match that of peer
I don't know if this can be helpful.
BTW, the behavior is the same for every error code check.
I'm guessing each of this is a bool you can check for 1 or 0. so if ESP_ERR_ESPNOW_NOT_INIT ==1 then that happened. Just keep thinking and looking things trying to trace them back to where they came from. It's always cryptic and requires effort.
sevenoutpinball:
Definitely not. They are surely constants against which status values returned by various functions are checked. Most likely #define(s) or enums.
That's where your experience bests mine. I am self taught in all of this stuff. But I run into this same thing myself, I can never find where these variables are defined or set. I had one today in fact, I tried doing a find on the variable and found nothing in the .h or the .cpp. So I don't know where this stuff is coming from.
But, even better than a good search tool is using a Real IDE for code development --- one that will let you trace variables, functions, classes, macros, etc back to their definition. I use Eclipse / Sloeber.
