Ok here it is.
void isp_setup() {
DDRF |= _BV(2) | _BV(3); // LEDs as output
int i;
for (i = 0; i < 10; i++)
PORTF ^= _BV(2) | _BV(3); // flash LEDs to indicate start of mode
delay(100);
autoerase = 0;
UCSR1B &= ~_BV(RXCIE1);
while(1) isp_loop();
int error=0;
int pmode=0;
// address for reading and writing, set by 'U' command
int here;
uint8_t buff[256]; // global block storage
char autoerase;
#define beget16(addr) (*addr * 256 + *(addr+1) )
typedef struct param {
uint8_t devicecode;
uint8_t revision;
uint8_t progtype;
uint8_t parmode;
uint8_t polling;
uint8_t selftimed;
uint8_t lockbytes;
uint8_t fusebytes;
int flashpoll;
int eeprompoll;
int pagesize;
int eepromsize;
int flashsize;
parameter;
parameter param;
void isp_loop(void) {
// is pmode active?
if (pmode) PORTF |= _BV(2);
else PORTF &= ~_BV(2);
// is there an error
if (error) PORTF &= ~_BV(3);
else PORTF |= _BV(3);
if ((UCSR1A & _BV(RXC1))) {
avrisp();
uint8_t getch() {
while(!(UCSR1A & _BV(RXC1)));
PORTF ^= _BV(3);
return UDR1;
void readbytes(int n) {
for (int x = 0; x < n; x++) {
buff[x] = getch();
void putch(char c) {
while (!(UCSR1A & _BV(UDRE1)));
PORTF ^= _BV(3);
UDR1 = c;
void spi_init() {
uint8_t x;
SPCR = 0x53;
x=SPSR;
x=SPDR;
uint8_t spi_send(uint8_t b) {
uint8_t reply;
SPDR=b;
loop_until_bit_is_set(SPSR, SPIF);
reply = SPDR;
return reply;
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
uint8_t n;
spi_send(a);
n=spi_send(b);
//if (n != a) error = -1;
n=spi_send(c);
return spi_send(d);
void empty_reply() {
if (CRC_EOP == getch()) {
putch((char)STK_INSYNC);
putch((char)STK_OK);
else {
putch((char)STK_NOSYNC);
void breply(uint8_t b) {
putch((char)b);
else {
void get_version(uint8_t c) {
switch(c) {
case 0x80:
breply(HWVER);
case 0x81:
breply(SWMAJ);
case 0x82:
breply(SWMIN);
case 0x93:
breply('S'); // serial programmer
default:
breply(0);
void set_parameters() {
// call this after reading paramter packet into buff[]
param.devicecode = buff[0];
param.revision = buff[1];
param.progtype = buff[2];
param.parmode = buff[3];
param.polling = buff[4];
param.selftimed = buff[5];
param.lockbytes = buff[6];
param.fusebytes = buff[7];
param.flashpoll = buff[8];
// ignore buff[9] (= buff[8])
//getch(); // discard second value
// WARNING: not sure about the byte order of the following
// following are 16 bits (big endian)
param.eeprompoll = beget16(&buff[10]);
param.pagesize = beget16(&buff[12]);
param.eepromsize = beget16(&buff[14]);
// 32 bits flashsize (big endian)
param.flashsize = buff[16] * 0x01000000
+ buff[17] * 0x00010000
+ buff[18] * 0x00000100
+ buff[19];
void start_pmode() {
spi_init();
// following delays may not work on all targets...
DDRB |= _BV(0); // SS pin as output
DDRE |= _BV(2); // reset pin as output
PORTE |= _BV(2); // reset pin high
DDRB |= _BV(1); // SCK pin as output
PORTB &= ~_BV(1); // SCK pin low
delay(50);
PORTE &= ~_BV(2); // reset pin low
delay(50);
DDRB &= ~_BV(3); // MISO pin as input
DDRB |= _BV(2); // MOSI pin as output
spi_transaction(0xAC, 0x53, 0x00, 0x00);
pmode = 1;
void end_pmode() {
// relevant pins as input
DDRE &= ~_BV(2);
PORTE &= ~_BV(2);
DDRB &= ~_BV(1);
PORTB &= ~_BV(2);
DDRB &= ~_BV(3);
PORTB &= ~_BV(1);
DDRB &= ~_BV(2);
PORTB &= ~_BV(3);
pmode = 0;
autoerase = 0;
void universal() {
int w;
uint8_t ch;
for (w = 0; w < 4; w++) {
buff[w] = getch();
ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
breply(ch);
void flash(uint8_t hilo, int addr, uint8_t data) {
spi_transaction(0x40+8*hilo,
addr>>8 & 0xFF,
addr & 0xFF,
data);
void commit(int addr) {
spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
//#define _current_page(x) (here & 0xFFFFE0)
int current_page(int addr) {
if (param.pagesize == 32) return here & 0xFFFFFFF0;
if (param.pagesize == 64) return here & 0xFFFFFFE0;
if (param.pagesize == 128) return here & 0xFFFFFFC0;
if (param.pagesize == 256) return here & 0xFFFFFF80;
return here;
uint8_t write_flash(int length) {
if (param.pagesize < 1) return STK_FAILED;
//if (param.pagesize != 64) return STK_FAILED;
int page = current_page(here);
int x = 0;
while (x < length) {
if (page != current_page(here)) {
commit(page);
flash(LOW, here, buff[x++]);
flash(HIGH, here, buff[x++]);
here++;
commit(page);
return STK_OK;
uint8_t write_eeprom(int length) {
// here is a word address, so we use here*2
// this writes byte-by-byte,
// page writing may be faster (4 bytes at a time)
for (int x = 0; x < length; x++) {
spi_transaction(0xC0, 0x00, here*2+x, buff[x]);
delay(45);
return STK_OK;
void program_page() {
char result = (char) STK_FAILED;
int length = 256 * getch();
length += getch();
if (length > 256) {
putch((char) STK_FAILED);
return;
char memtype = getch();
buff[x] = getch();
putch((char) STK_INSYNC);
if (memtype == 'F') result = (char)write_flash(length);
if (memtype == 'E') result = (char)write_eeprom(length);
putch(result);
else {
putch((char) STK_NOSYNC);
uint8_t flash_read(uint8_t hilo, int addr) {
return spi_transaction(0x20 + hilo * 8,
(addr >> 8) & 0xFF,
addr & 0xFF,
0);
char flash_read_page(int length) {
for (int x = 0; x < length; x+=2) {
uint8_t low = flash_read(LOW, here);
putch((char) low);
uint8_t high = flash_read(HIGH, here);
putch((char) high);
here++;
return STK_OK;
char eeprom_read_page(int length) {
// here again we have a word address
uint8_t ee = spi_transaction(0xA0, 0x00, here*2+x, 0xFF);
putch((char) ee);
return STK_OK;
void read_page() {
char result = (char)STK_FAILED;
length += getch();
if (CRC_EOP != getch()) {
return;
if (memtype == 'F') result = flash_read_page(length);
if (memtype == 'E') result = eeprom_read_page(length);
putch(result);
return;
void read_signature() {
return;
uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
putch((char) high);
uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
putch((char) middle);
uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
putch((char) low);
putch((char) STK_OK);
int avrisp() {
uint8_t data, low, high;
uint8_t ch = getch();
switch (ch) {
case '0': // signon
empty_reply();
case '1':
if (getch() == CRC_EOP) {
Serial1.print("AVR ISP");
case 'A':
get_version(getch());
case 'B':
readbytes(20);
set_parameters();
empty_reply();
case 'E': // extended parameters - ignore for now
readbytes(5);
empty_reply();
case 'P':
start_pmode();
empty_reply();
case 'U':
here = getch();
here += 256 * getch();
empty_reply();
case 0x60: //STK_PROG_FLASH
low = getch();
high = getch();
empty_reply();
case 0x61: //STK_PROG_DATA
data = getch();
empty_reply();
case 0x64: //STK_PROG_PAGE
program_page();
case 0x74: //STK_READ_PAGE
read_page();
case 'V':
universal();
case 'Q':
error=0;
end_pmode();
empty_reply();
case 0x75: //STK_READ_SIGN
read_signature();
// expecting a command, not CRC_EOP
// this is how we can get back in sync
case CRC_EOP:
// anything else we will return STK_UNKNOWN
default:
putch((char)STK_UNKNOWN);
ArduinoISP.pde (9.35 KB)
