Question about functions in libraries
Hi everyone, I am working on a library for an ultrasonic range finder. This one : http://www.seeedstudio.com/wiki/Ultra_Sonic_range_measurement_module
There is my first attempt for the code
Main:
#include <UltraSonicSensor.h>
long AltitudeUltraSonic;
int pin = 2;
  UltraSonicSensor().setPin(pin);
  AltitudeUltraSonic = UltraSonicSensor().Altitude();
  Serial.print("Altitude (cm): ");
  Serial.println(AltitudeUltraSonic);
  delay(100);
CPP
#include "Arduino.h"
#include "UltraSonicSensor.h"
void UltraSonicSensor::setPin(int pin)
  _pin = pin;
long UltraSonicSensor::Altitude()
  pinMode(_pin,OUTPUT);
  digitalWrite(_pin,LOW);
  delayMicroseconds(2);
  digitalWrite(_pin,HIGH);
  delayMicroseconds(10);
  pinMode(_pin,INPUT);
  pulseDuration = pulseIn(_pin,HIGH);
  return pulseDuration/(2*29);
Header
#ifndef UltraSonicSensor_h
#define UltraSonicSensor_h
class UltraSonicSensor
public:
  void setPin(int pin);
  long Altitude(int _pin);
private:
  long pulseDuration;
  int _pin;
#endif
So this code is not working because pulseIn is not getting any signal. It seems that _pin is not correctly set. I would like to know why?
I have found a workaround by setting the pin directly in the Altitude function by having an input argument.
Still I would like to know why the code above is not working.
Thanks
You have a few problems here.
In your setup you have this line
So this will create an instance of UltraSonicSensor and call it’s setPin function. BUT this is a totally pointless exercise as this instance is going to become non existent once the command is done as you don’t save the instance that you’re creating.
Further down in your loop, you have this line
This again is going to create an instance of UltraSonicSensor that only exists for this single command. Also this instance, (being quite a seperate instance to the one created in Setup) will not have any pin setup for it.
Furthermore, looking at your .h file, you have declared that an int variable should be passed to UltrasonicSensor.Altitude().
So try these mods to see if it gets you somewhat closer.
In your .h file you don’t need the pin to be passed to the Altitude function (as it gets set as a separate issue). So your class definition should look like this.
public:
  long Altitude(); //no need to pass the pin here
private:
  long pulseDuration;
  int _pin;
In your main sketch create a single instance of the UltraSonicSensor and use this instance througout,
voila
int pin = 2;
UltraSonicSensor myUS;
  myUS.setPin(pin);
  AltitudeUltraSonic = myUS.Altitude();
  delay(100);
