Question about hexadecimal
Hello guys,
I got "3838" as String. Like :
String example = "3838";
Which is equal to ( 88 ) as a hexadecimal. ( I converted here : Convert hexadecimal to text - Converters )
But I need to use it as a char like here :
char data[] = {0x88};
How can I do this ? Sorry for bad expression. Thank you very much.
char data[] = {0x88};It doesn't make much sense (to me at least) to have a single element array.
AWOL:
Yeah,
It's actually something like this :
char data[] = {0x88,0x0f,0xc7,0xae,0x76,0x85,0xe9,0xb1,0x8f,0x2f,0x2a,0xd3,0x60,0x37,0x6b,0x6d};
Why are you starting with a String?
It's about my code but I can't change it. I actually have "14392" decimal value which is equal to hexadecimal "3838". So It works if I can convert decimal 14392 to char 0x88.
0x38 is the ASCII representation 0f '8'. to convert to an integer:
split your string into the two separate numbers "38" and "38" and then use strtol(string, NULL, 16) to convert them to integers. You can then use
(int_msb - '0') * 16 + (int_lsb - '0') to convert it to a standard int.
I don't know how you got "3838", but it seems that it would be easier to do your conversion before that string is created when you get the ASCII '8'.
No, you have a binary value.
Simple mask and shift software will sort that out in no time.
If that scares you, lowByte and highByte will help.
Thanks for sharing, though I have no idea what that has to do with the OP.
