Question about how to have parallel servos working on one arduino board
Hi guys, I am new to the whole Arduino . I was working on the "flex" program, which works perfectly fine.
I was wondering what's code I need if I want to run two servos on the same arduino uno board, one using analog 0 and pin 9, the other one maybe using analog 1 and pin 10?
orginal code for one servo "flex":
// Based on File > Examples > Servo > Knob
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  Serial.println(val);
  val = map(val, 50, 300, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
Thanks :slight_smile:
You have all the information right there. The example is using analog pin 0 and 9. You're simply adding another one on your choice of pins. So add a second pot on whichever analog pin you want to use, and the servo on the other pin. Repeat the necessary lines, and try it. No better way to learn than to try it yourself.
