Question About Keyboard Project
Hey everyone,
I have built a small macro keyboard with an Arduino pro micro and some cherry mx switches, but for some reason, I am getting no response out of it. The keys do not provide an input when pressed, and sometimes I will receive inputs when nothing is being pressed. This was my first time soldering anything, and it was a bit messy, but I am fairly certain I soldered everything correctly. Also I feel kind of stupid saying this but, I have not built a case/stand for the keyboard, so I am just testing it barebones, with the PCB exposed (Image here), so maybe its possible I damaged it some way? Also, could my USB cord be the issue? I am using a micro USB, and it does fine to communicate with the Arduino and upload sketches, but could it be blocking my key inputs?
Anyway, here is the code I used to test it
Also here is the tutorial I tried to follow while making it
Thanks, and sorry for the super long post
@skink_
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Please post a clear picture of your setup; and post it here, not a link to somewhere. It looks like the top row of pins of the ProMicro does not have pins to the ‘motherboard’; not sure if they are important in this case (no promicro or schematic at hand).
Please post a schematic (photo of hand-drawn is fine); again, post it here.
In future, please post small code here in a post between
** **[code]** **
and
** **[/code]** **
; limit for a post is 9000 characters. I’ve done it now for you.
#include "Keyboard.h"
#include <Keypad.h>
  pinMode(A0, INPUT);
  pinMode(6,INPUT);
  pinMode(7,INPUT);
  pinMode(8,INPUT);
  pinMode(9,INPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(A3,OUTPUT);
  if (digitalRead(A0) ==HIGH  or digitalRead(18)==HIGH){
    Serial.println("hello");
  digitalWrite(4, HIGH);
  if (digitalRead(6) == HIGH){
    Serial.println("A key was pressed in row one, column one");
    delay(100);
  digitalWrite(4,LOW);
  digitalWrite(5,HIGH);
  if (digitalRead(7) == HIGH){
    Serial.println("A key was pressed in row two, column two");
    delay(100);
How to make a schematic you can post.
Do you have pull-down resistors on pins 6 and 7? If not, what is to keep them from floating HIGH when the buttons aren't pressed?
