So i made a 4x4x4 led cube with 2 shift registers. The cube has 4 layers of 16 led's wich have a common anode, there are also 16 rows with common cathode. I got a code wich works for the opposit, so the layers have common cathode and the rows common anode. But I dont realy know what I have to do in order to let it work properly for my cube. Help would be appreciated. Here is the code :
#define buttonPin 2
unsigned int layer[4] = {0, 0, 0, 0}; //65535 filled layer
byte k = 0;
bool start = true;
unsigned long delayTime;
int speedTime = 0;
int count;
InitializeShiftReg();
InitializeMyLedCube();
void InitializeMyLedCube() {
DDRD = B11110000; //pins D0-D3 as INPUTS, D4-D7 as OUTPUTS
PORTD |= B11110000; //turn OFF layers
pinMode(buttonPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(buttonPin), PushButton, FALLING);
delayTime = millis();
byte patternNum = 28;
byte pattern = patternNum - 1;
if (start) {
detachInterrupt(digitalPinToInterrupt(buttonPin));
delay(500); //wait for releasing PushButton
pattern++;
if (pattern > patternNum) pattern = 1;
count = 0;
if (((millis() - delayTime) > speedTime) || start) {
switch (pattern) {
case 1: LayersUpDown(); break;
case 2: FallingDot(); break;
case 3: Rain(); break;
case 4: AllCube(); break;
case 5: Cut(); break;
case 6: Cube(); break;
case 7: Diagonal(); break;
case 8: Mixer(); break;
case 9: Random(); break;
case 10: FallingLayer(); break;
case 11: LayerCut(); break;
case 12: Circle(); break;
case 13: RandomWay(); break;
case 14: SmallCube(); break;
case 15: RandomWayCube(); break;
case 16: GrowingCube(); break;
case 17: FallingLayers(); break;
case 18: GrowingLine(); break;
case 19: CircleEdges(); break;
case 20: CircleSide(); break;
case 21: RandomWayLine(); break;
case 22: RandomWaySide(); break;
case 23: DJCube(); break;
case 24: FillingCube(); break;
case 25: NanoBuilding(); break;
case 26: Curve(); break;
case 27: Snake(); break;
case 28: Julka(); break;
default: break;
//this part displays layers as they are set in functions
SetShiftReg(layer[k]); //send layer data to shift registers
bitClear(PORTD, 4 + k); //turn ON layer k
delay(1); //important for brightness of leds
k++; if (k > 3) k = 0; //take another layer in the loop
void PushButton() {
start = true;
#define latchPin 10 //PORT B2
#define clockPin 9 //PORT B1
#define dataPin 11 //PORT B3
#define resetPin 8 //PORT B0
void InitializeShiftReg() {
DDRB |= B1111; //pins D8-D11 as OUTPUTS
PORTB |= B0001; //resetPin to HIGH
void SetShiftReg(unsigned int value) {
bitClear(PORTB, 2); //digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, value >> 8); //shift out high byte, alternative: LSBFIRST / MSBFIRST
shiftOut(dataPin, clockPin, MSBFIRST, value); //shift out low byte, alternative: LSBFIRST / MSBFIRST
bitSet(PORTB, 2); //digitalWrite(latchPin, HIGH);
bool direct;
unsigned int actualValue;
byte lay, xVal, yVal;
byte place;
void SetLayers(unsigned int value) {
layer[0] = value; layer[1] = value; layer[2] = value; layer[3] = value;
void InversLayers() {
layer[0] = 65535 - layer[0];
layer[1] = 65535 - layer[1];
layer[2] = 65535 - layer[2];
layer[3] = 65535 - layer[3];
void ClearLayers() {
SetLayers(0);
void LayersUpDown() {
if (start) {
start = false; speedTime = 500;
direct = true;
ClearLayers();
layer[count] = 65535;
if (direct) {
count++;
if (count > 3) {
direct = false;
count = 2;
count--; if (count < 1) direct = true;
void FallingDot() {
if (start) {
start = false; speedTime = 100;
count = 4;
actualValue = 1;
direct = true;
count--;
ClearLayers();
layer[count] = actualValue;
if (count == 0) {
count = 4;
actualValue = actualValue << 1;
if (actualValue == 0) actualValue = 1;
void Rain() {
if (start) {
start = false; speedTime = 200;
ClearLayers();
layer[0] = layer[1];
layer[1] = layer[2];
layer[2] = layer[3];
layer[3] = 1 << random(16);
void Random() {
if (start) {
layer[0] = random(65536);
layer[1] = random(65536);
layer[2] = random(65536);
layer[3] = random(65536);
void AllCube() {
if (start) {
start = false; speedTime = 2000;
ClearLayers();
switch (count) {
case 0:
SetLayers(65535);
case 1:
layer[1] = 1632;
layer[2] = 1632;
count++; if (count > 1) count = 0;
void Cut() {
if (start) {
layer[0] = 4369;
layer[1] = 13107;
layer[2] = 30583;
layer[3] = 65535;
InversLayers();
void Cube() {
if (start) {
layer[0] = 15+16+128+256+2048+4096+8192+16384+32768;
layer[1] = 1+8+4096+32768;
layer[2] = layer[1];
layer[3] = layer[0];
InversLayers();
void Diagonal() {
if (start) {
layer[0] = 33825;
layer[1] = 33825;
layer[2] = 33825;
layer[3] = 33825;
InversLayers();
void Mixer() {
if (start) {
switch (count) {
case 0: actualValue = 33825; break;
case 1: actualValue = 17442; break;
case 2: actualValue = 8772; break;
case 3: actualValue = 4680; break;
case 4: actualValue = 960; break;
case 5: actualValue = 3120; break;
SetLayers(actualValue);
count++;
if (count > 5) count = 0;
void FallingLayer() {
if (start) {
actualValue = 0;
direct = false;
if (actualValue == 0) {
actualValue = 1;
ClearLayers();
direct = !direct;
layer[3 - (direct? 0:3)] = 65535;
switch (count) {
case 0:
layer[3 - (direct? 0:3)] -= actualValue;
layer[2 - (direct? 0:1)] = actualValue;
case 1:
layer[1 + (direct? 0:1)] = layer[2 - (direct? 0:1)];
layer[2 - (direct? 0:1)] = 0;
case 2:
layer[0 + (direct? 0:3)] += layer[1 + (direct? 0:1)];
layer[1 + (direct? 0:1)] = 0;
count++; if (count > 2) count = 0;
void LayerCut() {
if (start) {
if (count) layer[0] = layer[0] << 1;
else layer[0] = 4369;
SetLayers(layer[0]);
count++;
if (count > 20) count = 0;
void Circle() {
if (start) {
lay = 3;
switch (count) {
case 0: ClearLayers(); layer[lay] = 1; break;
case 1: layer[lay] = 2; break;
case 2: layer[lay] = 4; break;
case 3: layer[lay] = 8; break;
case 4: layer[lay] = 128; break;
case 5: layer[lay] = 2048; break;
case 6: layer[lay] = 32768; break;
case 7: layer[lay] = 16384; break;
case 8: layer[lay] = 8192; break;
case 9: layer[lay] = 4096; break;
case 10: layer[lay] = 256; break;
case 11: layer[lay] = 16; break;
case 12: layer[lay] = 1; break;
count++;
if (count > 12) {
count = 0;
if (lay == 0) lay = 3;
else lay--;
