Question about LEDControl Library
So I am having some difficulty working with LEDControl. I am trying to interface my Arduino pro mini with http://www.sparkfun.com/commerce/product_info.php?products_id=9622 and http://www.sparkfun.com/commerce/product_info.php?products_id=682 as far as I can tell every wire is hooked uped perfectly but when I turn it on all the LEDs are off. I put my code below and thanks for the help
#include "LedControl.h"
 pin 12 is connected to the DataIn
 pin 11 is connected to the CLK
 pin 10 is connected to LOAD
 We have only a single MAX72XX.
LedControl lc=LedControl(12,11,10,1);
/* we always wait a bit between updates of the display */
unsigned long delaytime=200;
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  lc.shutdown(0,false);
  /* Set the brightness to a medium values */
  lc.setIntensity(0,8);
  /* and clear the display */
  lc.clearDisplay(0);
  lc.setLed(0,2,7,true);
  lc.setLed(0,2,7,false);
I have also tried to use the matrix library with the same thing happening all the leds are just off.
Matrix myMatrix = Matrix(12, 10, 11);
  myMatrix.clear(); // clear display
  // turn some pixels on
  myMatrix.write(1, 5, HIGH);
  myMatrix.write(2, 2, HIGH);
  myMatrix.write(2, 6, HIGH);
  myMatrix.write(3, 6, HIGH);
  myMatrix.write(4, 6, HIGH);
  myMatrix.write(5, 2, HIGH);
  myMatrix.write(5, 6, HIGH);
  myMatrix.write(6, 5, HIGH);
So i figured out the problem if I use the tx and rx pins for the datain and load pins it works.
will the max7219 only work with the serial pins
