Dear friends,
I am supposed to make a Syringe Pump for our biomaterial laboratory with an accuracy about 100 ul/h with a 1 ml liter syringe which has about 5 mm inner diameter on a 2mm pitch rod (the more the better! ). I reviewed some projects on youtube and other websites in which they used Arduino Uno R3 and Adafruit Motor Shield[link] with a 12 VDC Stepper Motor[9.6 W, 1.8 deg] but I have no idea if they can achieve my desired rotational speed. Therefore, I would be appreciated if you could help me with the following questions:
-What is the minimum continuous speed of 12V DC stepper motors with 200[or 400] steps per rev? Can I get a "continues" 1 rpm speed from these stepper motors using the aforementioned Arduino board and Motor Shield? Should I provide a reprap to achieve this speed? As you know it is important for me to have the minimum speed in a continuous mode and any delay between steps would cause problems during my droplet generating project.
-I know that if I want to achieve this speed, the Arduino board and motor have to endure high "torque" and "current" and this might damage the system. Do you think that my desired rotational speed would cause damage to the system or not?
-Can you suggest any appropriate stepper motor which you got an accurate result in your projects?
Any other ideas would be highly appreciated!
Thank you for your time and consideration.
