Question about MOD math very confused
I was porting over a bit of code from Python to Arduino and came upon the following
in Python
(2-4)%5 yields 3
(4-2)%5 yields 2
on Arduino
(2-4)%5 yields -2
(4-2)%5 yields 2
So what am I missing here?
In python the modulo operator always yields a result with the same sign as the second operand, or zero.
So.... the short answer is "ain't gonna work"
Interesting problem and a bit surprising
Python match my HP48GX calculator
"ain't gonna work"
For some values of work.
You have to remember C's systems programming roots.
All well and good but doesn't solve my problem....
I'm working on a rock, paper,sicssors,lizard,spock idea and was staring with some python code that works Thus
diff=(player1-player2)%5
and where diff = 1 or 2 Player 1 wins
diff = 3 or 4 Player 2 wins
diff=0 tie
I guess I'll have to find a long winded if then solution
Bret:
in Python (2-4)%5 yields 3
If it is so, it is really confusing.
Whandall:
From what I've been reading this is what is expected from a mathematician point of view
Ok so here's what I've managed to work out...
From the thread at: How to code a modulo (%) operator in C/C++/Obj-C that handles negative numbers - Stack Overflow
The following works:
(diff+5)%5
Whandall:
Think about clock arithmetic. (2-4)%12=10. 2 o'clock less 4 hours is 10 o'clock.
But -2 % 5 = 3 ?
Whandall:
But -2 % 5 = 3 ?
On a 5 hour clock. Sure. 2 hours before 0 o'clock is...
Whandall:
But -2 % 5 = 3 ?
5 goes into -2 0 times with a remainder of -2. So to me it should be -2.
OR 0 times 5 = 0
0 + (-2) = -2
Delta_G:
OR 0 times 5 = 0
0 + (-2) = -2
Not disputing it.. Me I'm just trying to convert a python trick to Arduino and this solved it for me..
Note that in Python, -2/5 = -1
Math generally defines the remainder in integer division to be positive, see Euclidean division - Wikipedia
Taking the rice Python class? Me too!
Bret:
Try
diff=(player1-player2+5)%5
Think about it for a second, then slap your head and say "doh!".
Bret:
I'm working on a rock, paper,sicssors,lizard,spock idea ...
Dr. Spock or Mr. Spock?
PaulMurrayCbr:
Try
PaulMurrayCbr:
Try
As I posted above, that's what I did
Mr Spock.
There are two cycles in the group:
Scissors cuts paper, paper covers rock, rock crushes lizard, lizard poisons Spock, Spock smashes scissors
Scissors decapitates lizard, lizard eats paper, paper disproves Spock, Spock vaporizes rock, Rock blunts scissors
of course, there are subcycles. And there are some 7-element variants, but they are just silly.
