OmegaRA,
Have you been able to get your motor to even turn on, using the code I posted in reply #11 or UKHeliBobs in #20?
This would confirm whether your shield is working and your wiring is valid...
John
OmegaRA,
John
johncc:
OmegaRA,Have you been able to get your motor to even turn on, using the code I posted in reply #11 or UKHeliBobs in #20?
John
I was at work all day and didn't get to tinker. Just got home and finished dinner and a grocery shop will attempt the tinker now. Have to go downstairs and load your sketch to the UNO and hook it up to see.
UKHeliBob:
The fact remains that neither sketch uses 3 pins defined as outputs to control the shield......You need to start with simple sketches that run the motor(s) and work from there
Try thisint motorA_dir = 12; //direction
int motorA_brake = 9; //brake
int motorA_speed = 3; //speed
pinMode (motorA_dir, OUTPUT); //set 3 pins to be outputs
pinMode (motorA_brake, OUTPUT);
pinMode (motorA_speed, OUTPUT);
digitalWrite(motorA_dir,HIGH); //direction 1
digitalWrite(motorA_brake,LOW); //brake off
for (int motorSpeed = 0;motorSpeed <=255 ;motorSpeed++)
analogWrite(motorA_speed, motorSpeed); //set the motor speed
delay(100); //slow down the for loop a little
analogWrite(motorA_speed, 0); //let the motor coast to a stop
One motor should run up from its slowest speed to its highest then stop. Note how giving the Arduino pins names helps to make the code more readable.
I see what you are saying. I will give that a go as well, so obviously the sketch you provided is for a single motor, but once I get at least one working then it is a matter of adding the second..
johncc:
John
okay, yes, your sketch gets the one motor spinning ![]()
That's great-- your shield and wiring is working!
void leftMotor( int direction, int speed)
digitalWrite( LEFT_MOTOR, direction); //Establishes direction fwd/back
digitalWrite( LEFT_BRAKE , LOW); //Disengage the Brake
digitalWrite( LEFT_SPINNER, speed); //Spins the motor
Can you see how you would add a rightMotor() ?
Cheers,
John
johncc:
That's great-- your shield and wiring is working!void leftMotor( int direction, int speed)
void rightMotor( int direction, int speed)
digitalWrite( RIGHT_MOTOR, direction); //Establishes direction fwd/back
digitalWrite( RIGHT_BRAKE , LOW); //Disengage the Brake
digitalWrite( RIGHT_SPINNER, speed); //Spins the motor
Can you see how you would add a rightMotor() ? Cheers, John
seem right for this section of code?
Here is a quick attempt at adding the Right pins and void setup, a little confused as to where to put stuff in the loop...
Mowbot Test Sketch 1 -- Motor
const int RIGHT_MOTOR=13, RIGHT_BRAKE=8, RIGHT_SPINNER=11;
const int LEFT_MOTOR=12, LEFT_BRAKE=9, LEFT_SPINNER=3;
const int FORWARD=HIGH, REVERSE=LOW;
const int FULLSPEED=255;
digitalWrite( LEFT_MOTOR, direction); //Establishes direction of Channel A
digitalWrite( RIGHT_MOTOR, direction); //Establishes direction of Channel B
pinMode(LEFT_MOTOR, OUTPUT);
pinMode(LEFT_BRAKE, OUTPUT);
leftMotor( FORWARD, FULLSPEED);
pinMode(RIGHT_MOTOR, OUTPUT);
pinMode(RIGHT_BRAKE, OUTPUT);
rightMotor( FORWARD, FULLSPEED);
delay( 4000); // on and off every 4 seconds
leftMotor( FORWARD, 0 );
delay( 4000);
OmegaRa:
Here is a quick attempt at adding the Right pins and void setup, a little confused as to where to put stuff in the loop...void setup() // This runs once when you power up or reset
leftMotor( FORWARD, FULLSPEED); // *** don't need this here
rightMotor( FORWARD, FULLSPEED); // *** don't need this here
void loop() // This one loops over and over
delay( 4000);
} // it goes from here back to the start of loop instantly
I would recommend removing the indicated *** lines in setup, Compile and run, the motor should go on 4 seconds and then off 4 seconds, on 4, off 4. Then in loop() just change the leftMotors()s to rightMotor(). You're just making sure the motor works here.
Also see if you can add the lines in the loop, to test the reverse:
right fwd full
delay
right fwd 0 (stop)
delay
right reverse full
delay
Modify for both motors fwd, 1 fwd 1 reverse, half speed (128), etc.
Make sure you understand the concept that setup runs once, first-- and loop then runs forever, over and over.
Cheers,
John
Okay, I will test that out when I get home from work.
OmegaRa:
I am making a Robot Lawnmower and it is very basic.Does any of this seem wrong?
Besides learning with a first sketch that runs something that could seriously hurt someone?
What could seem wrong?
I built it with a blade cover, and it is low to the ground, small chance of it hurting someone, but I hear you.
johncc:
right fwd full
delay
right fwd 0 (stop)
delay
right reverse full
delayModify for both motors fwd, 1 fwd 1 reverse, half speed (128), etc.
Cheers,
John
Okay, I did all that and got the motors working, not both at the same time, but I got each motor to go forward and backward, and switching back and forth.
You could bury a powered cable under the lawn and use a magnetic field sensor or two on the mower to follow that like a toy line-follower robot. You'd get a perfect path every time regardless of wheel slip, etc. No map or mapping required, just one long piece of single conductor wire and some time making and filling very thin, shallow trenches.
Could probably run something like that with a Tiny.
GoForSmoke:
You could bury a powered cable under the lawn and use a magnetic field sensor or two on the mower to follow that like a toy line-follower robot. You'd get a perfect path every time regardless of wheel slip, etc. No map or mapping required, just one long piece of single conductor wire and some time making and filling very thin, shallow trenches.Could probably run something like that with a Tiny.
This is more or less the plan eventually. Right now I am just going to use it in my backyard, which is fully fenced in, so I don't need sensors yet, just bumpers to make it turn around should it run into anything.
here are links to a couple pictures of what it looks like so far
I have to properly mount the Board and give it some paint...but overall that is it, minus it's covers
OmegaRa:
Did they fail to run at the same time or was that how you programmed it ?
UKHeliBob:
OmegaRa:
Okay, I did all that and got the motors working, not both at the same time, but I got each motor to go forward and backward, and switching back and forth.Did they fail to run at the same time or was that how you programmed it ?
That was just how I programmed it to test. I tried adding the other motor in after and got both working.
Now that you know both motors are working you could do something like this to test the bumper switches:
/* Bumpers */
const int LEFT_BUMP = A2, RIGHT_BUMP = A3;
boolean bump(int pin) {
// there's fancier ways but for now you will understand this ...
if (digitalRead(pin) == LOW) // switches are wired to ground
return true;
return false;
and in loop do something like
// test the bumper switches
if (bump(LEFT_BUMP)){
leftMotor(FORWARD, FULLSPEED); // left motor on
rightMotor(FORWARD, 0); // right off
else if (bump( RIGHT_BUMP)){
// right motor on, left off
Remember to set INPUT_PULLUP in setup()...
Cheers,
John
Okay guys here is my final sketch
I have a video of it working too, but it is still uploading. I will link to it later when it is done. I need to head to work soon.
EDIT: here is a link to the video on my Skydrive. http://sdrv.ms/VQMzDs
and on youtube My Robo Mower - YouTube
Mowbot Sketch
/* Bumpers */
const int LEFT_BUMP = A2;
const int RIGHT_BUMP = A3;
// there's fancier ways but for now ...
return true;
return false;
pinMode(LEFT_BUMP, INPUT_PULLUP);
pinMode(RIGHT_BUMP, INPUT_PULLUP);
int randNumber = random(900, 2500);
if (bump(LEFT_BUMP)) // left bumper hit
leftMotor(REVERSE, FULLSPEED); // backup
rightMotor(REVERSE, FULLSPEED);
delay(1500);
leftMotor(REVERSE, FULLSPEED); // turn
rightMotor(FORWARD, FULLSPEED);
delay(randNumber); // a random amount
else if (bump(RIGHT_BUMP))
delay(1500);
delay(randNumber);
} // then back to loop(), over and over
Congratulations on getting it working. Your code is fairly easy to read but I would suggest making each of the sets of motor controls into a function, each with a meaningful name. Some of the functions, such as the ones for forward and reverse would be called more than once and using functions would make it easier to understand the flow of the code. A function to make the mower spin in a random direction could also help to mix up the movement a little too.
Another point, it is not very kind to the motors to go from full speed forward to full speed backwards without a period of time when they are stopped. It would be even kinder to the motors to bring them up to full speed over a period of time rather than instantaneously, but that can be added to your present code. You could do this inside the functions that I have suggested using as there would then only be one place to implement the changes.
Have you tried the mower on grass yet ? The motor driving the blade looks too small to deliver much power, but maybe not.
as it is winter, there is no grass to cut sadly. But once the snow melts and it warms up a bit I will try it out on the grass. The blade I made is pretty lite and it spins very quickly on the motor, we'll see what happens when there is a little resistance with grass. As for your other points, they make sense, but I don't really know anything about coding to be able to properly implement them. It is something I can work on in the future, but for now I Am just glad I got it working.
