Question about Nano BLE transfer speed through C# program
Hi, I have a project to transfer IMU data over BLE with C# program.
And I found that if I disconnect BLE through program and without restart the power, the transfer speed would drop.
For example, the transfer speed with first connecting was 50 Hz, the second time would drop to 30 Hz, the third time would drop to 10 Hz and so on.
I wonder know if anybody had the same question and how to solve it.
Below link is my reference with C# program.
https://www.programmersought.com/article/51155122138/
I had modified the function FindService and FindCharacteristic, my program could normal execute.
And below is part of my Arduino code.
#include "Arduino.h"
#include <ArduinoBLE.h>
#include <Arduino_LSM9DS1.h>
#define BLE_IMUBUFFER_SIZES             45
#define BLE_DEVICE_NAME                "NTPU ESA LC BLE"
#define BLE_LOCAL_NAME                "NTPU ESA LC BLE"
BLEService BLESensors("a2ea6c2e-9475-4a9e-aa5d-e190a8b8830c");
BLECharacteristic IMUBLE("0001", BLERead | BLENotify | BLEBroadcast, BLE_IMUBUFFER_SIZES);
byte IMUpacket[45] = {IMUheader[0],IMUheader[1],
                      previousIMUTimes[0],previousIMUTimes[1],previousIMUTimes[2],previousIMUTimes[3],previousIMUTimes[4],
                      body[1],
                      AccXb[0],AccXb[1],AccXb[2],AccXb[3],
                      AccYb[0],AccYb[1],AccYb[2],AccYb[3],
                      AccZb[0],AccZb[1],AccZb[2],AccZb[3],
                      GyroXb[0],GyroXb[1],GyroXb[2],GyroXb[3],
                      GyroYb[0],GyroYb[1],GyroYb[2],GyroYb[3],
                      GyroZb[0],GyroZb[1],GyroZb[2],GyroZb[3],
                      MagXb[0],MagXb[1],MagXb[2],MagXb[3],
                      MagYb[0],MagYb[1],MagYb[2],MagYb[3],
                      MagZb[0],MagZb[1],MagZb[2],MagZb[3],
                      (byte)Count
    if (!BLE.begin())
        while (1);
        BLE.setDeviceName(BLE_DEVICE_NAME);
        BLE.setLocalName(BLE_LOCAL_NAME);
        BLE.setAdvertisedService(BLESensors);
        BLESensors.addCharacteristic(IMUBLE);
        BLE.addService(BLESensors);
        BLE.advertise();
        if (!IMU.begin())
          Serial.println("Failed to initialize IMU!");
          while (1);
        IMU.setAccelFS(3);
        IMU.setAccelODR(3);
        IMU.setAccelOffset(-0.017249, 0.017463, -0.02762);
        IMU.setAccelSlope (1, 1, 1);
        *******  FS  Full Scale         range 0:±2g | 1:±24g | 2: ±4g | 3: ±8g  (default=2)                                           ******
        *******  ODR Output Data Rate   range 0:off | 1:10Hz | 2:50Hz | 3:119Hz | 4:238Hz | 5:476Hz, (default=3)(not working 6:952Hz) ******
        IMU.setGyroFS(3);
        IMU.setGyroODR(3);
        IMU.setGyroOffset(-0.266289, -0.21708, 0.528232);
        IMU.setGyroSlope (1, 1, 1);
        *******  FS  Full Scale       setting 0: ±245°/s | 1: ±500°/s | 2: ±1000°/s | 3: ±2000°/s                                     ******
        *******  ODR Output Data Rate setting 0:off | 1:10Hz | 2:50Hz | 3:119Hz | 4:238Hz | 5:476Hz, (default=3)(not working 6:952Hz) ******
        IMU.setMagnetFS(0);
        IMU.setMagnetODR(6);
        IMU.setMagnetOffset(0,0,0);  //  uncalibrated
        IMU.setMagnetSlope (1,1,1);  //  uncalibrated
        ****  FS  Full Scale        range (0=±400 | 1=±800 | 2=±1200 | 3=±1600  (µT)                                              *****
        ****  ODR Output Data Rate  range (6,7,8)=(40,80,400)Hz | not available on all chips (0..5): (0.625,1.25,2.5,5.0,10,20)Hz *****
        IMU.accelUnit = GRAVITY;
        IMU.gyroUnit= DEGREEPERSECOND;
        IMU.magnetUnit = MICROTESLA;
    pinMode(LED_BUILTIN, OUTPUT);
    BLEDevice central = BLE.central();
    if(central)
        TimeReset();
        bool dataGotFlag = false;
        while(central.connected())
            digitalWrite(LED_BUILTIN, HIGH);
            preMicroTime = micros();
            Intervalcal();
            if(IMU.accelAvailable() && IMU.gyroAvailable())
                IMU.readAccel(Acc[0], Acc[1], Acc[2]);
                IMU.readGyro(Gyro[0], Gyro[1], Gyro[2]);
                pointAccXb = (byte *)&Acc[0];
                pointAccYb = (byte *)&Acc[1];
                pointAccZb = (byte *)&Acc[2];
                pointGyroXb = (byte *)&Gyro[0];
                pointGyroYb = (byte *)&Gyro[1];
                pointGyroZb = (byte *)&Gyro[2];
                dataGotFlag = true;
            if(IMU.magnetAvailable())
                IMU.readMagnet(Mag[0], Mag[1], Mag[2]);
                pointMagXb = (byte *)&Mag[0];
                pointMagYb = (byte *)&Mag[1];
                pointMagZb = (byte *)&Mag[2];
                dataGotFlag = true;
            if(dataGotFlag)
                IMUpacket[2] = (byte)Hour;
                IMUpacket[3] = (byte)Min;
                IMUpacket[4] = (byte)Sec;
                IMUpacket[5] = (byte)(Msec/256);
                IMUpacket[6] = (byte)(Msec%256);
                TurnToByte();
                CountNum();
                IMUpacket[44] = (byte)Count;
                IMUBLE.writeValue(IMUpacket,45);
            proMicroTime = micros();
            Timer();
        digitalWrite(LED_BUILTIN, LOW);
Welcome to the forum
I would recommend, you use a generic BLE smartphone app e.g. BLE Scanner on iOS to confirm whether the issue comes from the Arduino sketch or your PC?
I noted, your characteristics UUID is 16-bit which is not allowed. Custom services and characteristics must use 128-bit random UUIDs.
Klaus_K:
Thanks for your answer.
I had already used the app "nRF Connect" and "BLE Scanner" on IOS to connect my BLE and it could work well.
But all this app can't save the log to make sure transfer speed.
Or is there any way for me to find out the transfer speed by these two app?
And the characteristics UUID is refer to my reference URL,I found that if I set 0001, the result characteristics UUID would be "00000001-0000-1000-8000-00805f9b34fb", if I set 0002 result characteristics UUID would be "00000002-0000-1000-8000-00805f9b34fb".And then, if the UUID is not allowed, I think could't read the Data.
