question about Neopixel code
can someone pls tell me if the bit of code below is a type of array? it dosnt have the format of array but, im sure its normally used in a for loop, which begs the question where the values for each pixel is stored if it isnt an array of some sort.
strip.setPixelColor(n, red, green, blue);
It is not an array. It is a call to the setPixelColor() of the neopixel library with 4 parameters. The first is the number of the LED to be set and the other 3 are values for the red, green and blue components of the colour to be shown by the LED.
The LED number would often (but not always) be taken from a for loop index variable and the colour values from elsewhere which could be one or more arrays.
If you had posted a full program then more advice would have been given.
UKHeliBob:
It is not an array.
But it is a function that fills one array element.
The Neopixel lib uses an array (three bytes for each led), .show() transfers the array to the strip.
Whandall:
the constructor defines the size of the NeoPixel array:
  // Constructor: number of LEDs, pin number, LED type
  Adafruit_NeoPixel(uint16_t n, uint8_t p=6, neoPixelType t=NEO_GRB + NEO_KHZ800);
that array may be either three (RGB) or four (RGBW) bytes for each led:
  uint16_t
    numLEDs,       // Number of RGB LEDs in strip
    numBytes;      // Size of 'pixels' buffer below (3 or 4 bytes/pixel)
