Question about Nodebot Pressure Sensor
I am currently working a project which requires me to interface the Arduino board with Nodebot and Johnny-Five (GitHub - rwaldron/johnny-five: JavaScript Robotics and IoT programming framework, developed at Bocoup.). I got the first tutorial to work (with the LED light) but I don't know how to proceed in regards to interfacing the pressure sensor. The pressure sensor I am using is the MPX4115A. The code I used in the Arduino IDE (also has temp sensor code) is:
int pressureValue;
float pressure;
float temperatureC;
float altitude;
float currentaltitude;
float num1;
float num2;
float num3;
float num4;
float num5;
void setup (){
  Serial.begin (9600);
void loop (){
  int sensorValue=analogRead(A0);
  float voltage=sensorValue *(5.0/1023.0);
  temperatureC=(voltage-0.5) * 100;
  Serial.print(voltage);
  pressureValue=analogRead(A1);
  pressure=((pressureValue/1024.0) +0.095)/0.0009;
  num1 = pressure*100.0;
  num2 = num1/101325.0;
  num3 = log10 (num2);
  num4 = (num3/5.25588);
  num5 = pow(10.0, num4) - 1.0;
  altitude = num5/-0.0000225577;
  currentaltitude = 112.02;
  altitude = altitude+currentaltitude;
  Serial.print(",");
  Serial.print(pressure);
  Serial.print(",");
  Serial.println(altitude);
My question is how would you go about writing the code for the pressure sensor in Javascript and where would it be displayed? I am new to JS and require some assistance in regards to it.
Thanks,
Why Javascript? Arduino is programmed in C++. Are you asking how to write a Javascript program for the PC side to read the serial output from the Arduino and display on the PC?
groundfungus:
Yes, I am trying to write a Javascript program for the PC side to read the serial output from the Arduino and display on the PC using Nodebot (http://nodebots.io/) and Johnny-Five.
Since this is an Arduino forum that deals with the Arduino IDE and C++, you can't expect answers to your questions dealing with Java, Nodebots and Johnny-Five. You may get answers, but don't be too disappointed if you don't.
Or if they are wrong. 8)
I will try some different forums then.
Thanks,
