Question About Pneumatic Cylinder Control Project
Dear All,
I want to detect the changes of the surface level while moving and to process&forward this data to my pneumatic cylinders which will be expected to make the equal-inverse movement of the change. I think I should use an IMO or some board which has accelerometer and gyro sensors inside.
I'm a pure mechanic and a newbie to arduino electronics. I set up the pneumatic schema&system but would You please suggest me which model or type of electronic equipments should I use in my project.
Thank You in advance for Your help.
If the assembly is stationary, you can use an accelerometer as a tilt sensor and I expect you'll be able to find examples doing that.
If it's moving I think you will need a gyro and accelerometer and some clever maths to combine them - for this solution I suggest you search for the algorithms used to control flying drones.
Thanks for the reply Peter!
It's moving. I will check the drones for the math.
