Question about pointers
I would like to give a name to different elements of a boolean array, like use Red for Array[1], Blue for Array[2], etc.
I test this using the following sketch but get errors when I try to Serial.print the values.
What is wrong?
sketch_apr29a.ino (228 Bytes)
Post the code.
Post the error messages.
Before you do anything else please take a moment to read General guidance and
How to use this forum
Especially item #7 on posting code.
Thank you.
OP's code:
bool Sw[5] = {true,false, false, true, true};
bool *Test0;
bool *Test1;
Test0 = &Sw[0];
Test1 = &Sw[1];
  Serial.print   (Test0);
  Serial.println (Test1);
Which uses pointers and doesn't realize you have to dereference them.
This is probably more elegantly done with an enumeration (enum) for the array index, or even #define
swdick:
Maybe a simpler approach would be like this
byte Red = 1;
byte Blue = 2;
redVal = Array[Red];
blueVal = Array[Blue];
…R
As MarkT says...
Serial.print   (*Test0);
Serial.println (*Test1);
But better...
#define Test0 0
#define Test1 1
Serial.print   (Sw[Test0]);
Serial.println (Sw[Test1]);
This appears to do close to what you want. By using references (&) instead of pointer (*) the value doesn't have to be explicitly dereferenced.
bool Sw[5] = {true, false, false, true, true};
const bool &Test0 = Sw[0];
const bool &Test1 = Sw[1];
Yes, this does the trick. Thanbks a lot.
