Question about programming syntax
what this part of the code means? why question mark and what “:Null” after print action do?
(seconds < 10) ?display.print("0"):NULL;
I am trying this code that I found on GitHub and I will use this timer as a subpart of my project, the simulation runs perfectly. here is the full code:
  This is an example sketch for a countdown timer using Nokia 5110 LCD
  and adafruit library for the display
  RWSDev.net
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
// pin 7 - SCE
// pin 6 - RST
// pin 5 - D/C
// pin 4 - DN
// pin 3 - SCLK
// set timer position on lcd
int xPos = 16;
int yPos = 16;
int hours = 0;
int minutes = 1;
int seconds = 10;
Adafruit_PCD8544 display = Adafruit_PCD8544(7, 6, 5, 4, 3);
void setup()   {
  display.begin();
  display.clearDisplay();   // clears the screen and buffer
  display.display();
  while (hours > 0 || minutes > 0 || seconds >= 0) {
    display.setContrast(30);
    display.setCursor(xPos, yPos);
    (hours < 10) ? display.print("0") : NULL;
    display.print(hours);
    display.print(":");
    (minutes < 10) ? display.print("0") : NULL;
    display.print(minutes);
    display.print(":");
    (seconds < 10) ? display.print("0") : NULL;
    display.print(seconds);
    display.display();
    stepDown();
void stepDown() {
  if (seconds > 0) {
    seconds -= 1;
    if (minutes > 0) {
      seconds = 59;
      minutes -= 1;
      if (hours > 0) {
        seconds = 59;
        minutes = 59;
        hours -= 1;
        trigger();
void trigger() {
  display.setTextSize(1);
  display.println("Time over");
  display.display();
same
if(seconds < 10)
display.print("0");
// do nothing (NULL)
That (?:) is called the conditional or ternary operator.
amnahbukair:
That is the ternary operator, and is equivalent to:
    if (seconds < 10)
      display.print("0");
      NULL;
Note that this is an incorrect use of NULL, and will generate warning messages from the compiler if you have the IDE set to display all warnings.
/home/pi/Arduino/forumTest/forumTest.ino: In function 'void loop()':
/home/pi/Arduino/forumTest/forumTest.ino:39:41: warning: converting to non-pointer type 'unsigned int' from NULL [-Wconversion-null]
/home/pi/Arduino/forumTest/forumTest.ino:42:43: warning: converting to non-pointer type 'unsigned int' from NULL [-Wconversion-null]
/home/pi/Arduino/forumTest/forumTest.ino:45:43: warning: converting to non-pointer type 'unsigned int' from NULL [-Wconversion-null]
That particular line of code prints a leading “0” if the number of seconds is from 0 through 9.
Somebody wanted to see if he understood “ternary”. Completely wrong.
Just "
if (hours <10) display.print ('0');
And that for all 3 cases.
display.print ((hours <10) ? "0" : ""); :smiley:
