Question about project
I need to read a value off of a potentiometer which will be 0 - 5V. I then need to assign a variable so it is 1 of 23 based on the voltage at the pot. Basically you turn the handle on the pot and it counts from 1 to 23 as you turn it.
I am then going to have that value trigger a nixie display that counts from 1 to 23. is there a function like a table I could fill out assigning the ranges for each position to keep from having 24 if statements?
Look into the Arduino reference and search for the map function!
int val = analogRead(potPin) / 44;
int analogValue = analogRead(potPin)
int count = map(analogValue, 0, 1023, 0, 23);
See Arduino - map() function
  int val = analogRead(A0) / 44;
  Serial.println(val);
Sketch uses 2452, bytes (7%) of program storage space.
  int analogValue = analogRead(A0);
  Serial.println(count);
Sketch uses 2,744 bytes (8%) of program storage space.
Difference, 292 bytes, map can be expensive. :wink:
My worry about the map function is that how it works is not transparent
However it does simplify the actual math. (Thanks Erik!)
jwags818:
IoT_hobbyist:
See [Arduino - map() function](https://arduinogetstarted.com/reference/arduino-map)
Make that:
int count = map(analogValue, 0, 1023, 1, 23);
johnerrington:
You have the source, and it's described here
