I would like to use a 100A 50mv shunt to measure the current in a 30 amp circuit. Since the arduino can read less than 5v I figured I can it to read the measure up to 50mv. Then do the proper math to calculate the current running through the shunt.
My question is, is this a good idea to do? Is it safe, and accurate way to measure this small voltage?
Look for INA219 and INA169 at Adafruit and Sparkfun. See if those can be useful for you.
With high current, you have to design/wire your project carefully. A high ground current can decide to take a detour and go via or through the Arduino board.
The above, and 50 mV is really the bottom end of the scale. Even using the fixed built-in reference the analog reading will be about 50 at 50 mV input. You would need an amplifier circuit to bring the 50 mV to 1V, then you can get a decent resolution when measuring such small voltages.
TonyWilk:
However, the INA219 and INI169 only read to 3A and 5A respectively.
That's because of the 0.1ohm shunt resistor on the breakout boards.
If you connect a 100A shunt in parallel to that 0.1ohm shunt, then those boards can measure higher currents.
There are restrictions though. The INA219 is designed for ~12volt high-side measurements.
Need to know the galvanic relationship between the Arduino and the shunt.
Leo..
