question about returning pointer from a function (syntax)
I hav a question about returning a pointer from a function. Are the following two function equivalent (the return statement is different)?
If they are how come they are the same?
uint8_t buff[16];
uint8_t * get_live_reading(int *readinglen)  /
    memset(buff, 0, sizeof(buff));
    int temp_c = readsensor();
    buff[0] = 'T';
    buff[1] = 'C';
    buff[2] = temp_c&0xff;
    buff[3] = (temp_c>>8)&0xff;
    buff[4] = (temp_c>>16)&0xff;
    buff[5] = (temp_c>>24)&0xff;
    *readinglen = 6;
    return (&buff[0]);
uint8_t buff[16];
    buff[0] = 'T';
    buff[1] = 'C';
    *readinglen = 6;
    return (buff);
I don't know if they are the same; the returned result is the same.
buff is an array; for arrays, it's the pointer to the first element.
buff[0] is the content of the first element; & takes the address of that element and hence &buff[0] points to the first element.
So in both cases, you return a pointer to the first element.
Yes they are the same thing
buff is already a pointer to the start of the array
Guix,
How is buff already a pointer to the start of the array? I thought it is just an array. Or this just the way c works?
Yes buff is equivalent to a pointer to an array.
int array [10] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10};
int x = array [1];
int y = *(array + 1);
int z = 1[array];
Will result in x, y and z all being assigned the value 2.
Why do you need the function to return a pointer to a global variable? Whatever is calling the function will already have access to the global variable (array or not).
