Question about RTC function library
Hello guys,
I am very new to Arduino stuff and I am having trouble with RTC. I am setting up a automatic greenhouse. In the process I want to press a button, when this button is pressed the date will be saved and it starts counting 2 weeks in time from "now". I cant seem to find a library that has a function for this job and I cant figure it out. If any of u guys know how to make it work please leave your suggestion here.
Im using the library "RTC".
if you use adafruit/RTClib there are a DateTime and TimeSpan classes that could make your life easy.
have a look at their datecalc.ino example
Hey thanks, I will take a look right now.
There's a problem now im using the RTClib but keep having and error
I cant write on the loop don't understand why, for me it being on setup won't work cause i need it to be constantly verifying conditions.
Move your declaration for dt20 so that it's not inside the function where it's first used. It's not in scope in loop().
What RTC are you using? You want to find a library directly for the RTC you have.
