Sure !
Here is the full code, function is readBit(): 694 bytes. Function sendBit() which is quite similar is only 246 bytes.
I also suspect (not confirmed) the same issue for functions:
- readTemp(): 1400 bytes
- resetWire(): 1338 bytes
Regards,
Grégoire.
------------ Code ---------
#define NOTEMP 0xFFFF
int pintemp=2;
int pinrfpwr=3;
int pinrfdat=4;
byte tabcrc[256]={
0, 94,188,226, 97, 63,221,131,194,156,126, 32,163,253, 31, 65,
157,195, 33,127,252,162, 64, 30, 95, 1,227,189, 62, 96,130,220,
35,125,159,193, 66, 28,254,160,225,191, 93, 3,128,222, 60, 98,
190,224, 4, 92,223,129, 99, 61,124, 34,192,158, 29, 67,161,255,
70, 24,250,164, 39,121,155,197,132,218, 56,102,229,187, 89, 7,
219,133,103, 57,186,228, 6, 88, 25, 71,165,251,120, 38,196,154,
101, 59,217,135, 4, 90,184,230,167,249, 27, 69,198,152,122, 36,
248,166, 68, 26,153,199, 37,123, 58,100,134,216, 91, 5,231,185,
140,210, 48,110,237,179, 81, 15, 78, 16,242,172, 47,113,147,205,
17, 79,173,243,112, 46,204,146,211,141,111, 49,178,236, 14, 80,
175,241, 19, 77,206,144,114, 44,109, 51,209,143, 12, 82,176,238,
50,108,142,208, 83, 13,239,177,240,174, 76, 18,145,207, 45,115,
202,148,118, 40,171,245, 23, 73, 8, 86,180,234,105, 55,213,139,
87, 9,235,181, 54,104,138,212,149,203, 41,119,244,170, 72, 22,
233,183, 85, 11,136,214, 52,106, 43,117,151,201, 74, 20,246,168,
116, 42,200,150, 21, 75,169,247,182,232, 10, 84,215,137,107,53
void measTime(unsigned long start, unsigned long delay) {
unsigned long top;
unsigned long t1,t2;
unsigned long t;
do {
top = micros();
if( top < start ) { // timer loop every 70minutes
t1=start-top-1;
t2=0xFFFFFFFF;
t=t2-t1;
start=0;
top=t;
t=top-start;
while( t<delay );
return;
void sendBit(byte pin, byte bit) {
unsigned long start = micros();
digitalWrite(pin,LOW);
pinMode(pin,OUTPUT);
if( bit==1 ) {
measTime(start,10ul);
pinMode(pin,INPUT);
measTime(start,60ul);
else {
pinMode(pin,INPUT);
measTime(start,65ul);
byte readBit(int pin) {
unsigned long start=micros();
noInterrupts();
measTime(start,2ul);
pinMode(pin,INPUT);
byte value = digitalRead(pin);
interrupts();
while( digitalRead(pin)==0 );
return value;
void sendByte(byte pin, byte data) {
byte i,b;
for( i=0 ; i<8 ; i++ ) {
b=data&0x01;
sendBit(pin,b);
data=data>>1;
byte readByte(byte pin) {
byte data=0;
byte i,d;
d = readBit(pin);
data = data | (d<<i);
return data;
// Return 1 in cas of success
byte resetWire(byte pin) {
unsigned long start;
// Write 0 for at least 480us. Choose 500us.
start = micros();
measTime(start,500ul);
// Slave must answer a 0 between 15 and 60, and goes up between 75 to 300us
// Choose measure at 65us.
start = micros();
pinMode(pin,INPUT);
byte level = digitalRead(pin);
byte present=0;
if( level==LOW )
present=1;
while( digitalRead(pin)==LOW );
return present;
int readTemp(byte pin) {
int temp=NOTEMP;
byte i,d;
byte crc,index;
byte wdata[8];
byte wcrc;
d = resetWire(pin);
if(d==1) {
sendByte(pin,0xCC);
sendByte(pin,0x4E);
sendByte(pin,0); // low threshold
sendByte(pin,1); // high threshold
sendByte(pin,31); // 9 bits conversion
resetWire(pin);
sendByte(pin,0xCC);
sendByte(pin,0x44);
do {
d=readBit(pin);
while(d==0);
resetWire(pin);
sendByte(pin,0xCC);
sendByte(pin,0xBE);
d=readByte(pin);
wdata[i]=d;
wcrc=readByte(pin);
crc=0;
index=crc^wdata[i];
crc=tabcrc[index];
if( crc==wcrc ) {
temp=wdata[1]<<8 | wdata[0];
boolean neg = wdata[1]>>7 == 1;
if( neg ) temp = (!temp)-1;
byte degree=temp>>4;
byte t=(temp>>2) & 0x03;
byte values [4]={0,25,50,75};
byte cdegree=values[t];
temp = degree*100 + cdegree;
if( neg ) temp = (!temp)+1;
return temp;
void rfsend(byte pin,unsigned int period, byte b0, byte b1, byte b2, byte b3) {
byte synchro=B10101010;
byte start=B11001100;
rfsendbyte(pin,period,synchro);
rfsendbyte(pin,period,start);
rfsendbyte(pin,period,b0);
rfsendbyte(pin,period,b1);
rfsendbyte(pin,period,b2);
rfsendbyte(pin,period,b3);
void rfsendbyte(byte pin,unsigned int micro,byte b) {
int i=0;
for( int i=0 ; i<8 ; i++ ) {
byte data = b&B10000000;
b=b<<1;
if( data==0 ) {
digitalWrite(pin,HIGH);
delayMicroseconds(micro);
else {
pinMode(pintemp,INPUT);
digitalWrite(pintemp,LOW);
pinMode(pinrfpwr,OUTPUT);
digitalWrite(pinrfpwr,LOW);
pinMode(pinrfdat,OUTPUT);
digitalWrite(pinrfdat,LOW);
byte tl,th;
int temp = readTemp(pintemp);
if( temp != NOTEMP ) {
digitalWrite(pinrfpwr,HIGH);
delay(10);
tl = temp & 0xFF;
th = temp>>8 & 0xFF;
rfsend(pinrfdat,1000,'d',0, th, tl);
delay(5000);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
